help with fuel pressure gauge install
Old Sep 28, 2002 | 02:00 PM
rxotic's Avatar
all of you who have installed a fuel pressure gauge... Where did you tap the sender? what fittings did you use? pictures or web site links welcome!
Old Sep 28, 2002 | 02:10 PM
jspecracer7's Avatar
1JZ powered
Put the sensor in the aftermarket fuel pressure regulator.
Old Sep 28, 2002 | 02:16 PM
rxotic's Avatar
do not have one
Old Sep 29, 2002 | 08:11 PM
puma's Avatar
canadian monster
check out rob robinette
http://www.rx7turboturbo.com/robrobi...uelp_gauge.htm
Old Sep 29, 2002 | 11:35 PM
Flybye's Avatar
It's never fast enough...
I tapped right into the inlet fuel hose on the left side of the engine. I cut the hose, installed a junction with a tap on it, and screwed the sender there.
Rotospectre
Mar 28, 2018 03:33 PM
andyvideopro
Aug 20, 2015 10:55 AM
