R.p.m...
Old Sep 27, 2002 | 08:48 PM
R.p.m...
hey...let me ask you..I have a 84 rx7can't seem to get the R.P.M down to 750 or 850 what ever.. it has a/c any idea's...Thanks
Old Sep 27, 2002 | 08:54 PM
Manntis's Avatar
add to cart
not to state the obvious, but you've been turning the Idle screw, right?
Old Sep 27, 2002 | 10:58 PM
drewroman's Avatar
meh...
I had a similar problem once, and it turned out to be a vacuum leak...
the anti-afterburn hose was what got me (it's about a 3/8"-1/2" rubber line on the rear passenger side of the engine going from around the carb to the lower part of the intake manifold) damn thing is right near the exhaust manifold and there was a hole in it that I'd describe as HUGE..., because the hole was so large I couldnt' hear it like you would a smaller one...
I found it with a little carb/injector cleaner...
Old Sep 28, 2002 | 09:38 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
pull the rats nest.
my engine runs rock smooth at 400 rpms. sounds tight as hell.
I got it set rich as ****.
Old Sep 29, 2002 | 03:14 AM
DriftinJim's Avatar
Spray starting fluid on all the vacuum lines to check for a vacuum leak...if the rpms increase, you've found the leak. Even a pinhole can be problematic. Otherwise, make sure the timing is set correctly and adjust the idle speed and a/f screw accordingly.
