Idle speed help!
A few ideas:
- throttle cable too tight
- dashpot misadjusted
- primary throttle plates clearance out of spec (unlikely)
- lock nut (8mm) on top of intake opens throttle plates too much
BTW, idle speed should be adjusted with initial set coupler jumped
Hugues -
Hugues -
good call j9fd3s, I forgot about that one.
the thermowax keeps the throttle plates open to let the engine warm up (fast idle) for a few minutes. If its cam does not disengage, the idle will stay high.
hugues -
hugues -
I just rebuilt the engine it seems to be running fine all but idle speed I know that the fast idle cam is out of adjustment when i adjust the cam to the 2 marks on the roller it doesnt want to take gas and runs terrible how can I solve this problem when I open the bac at all it idles erratically it is closed now. It also will not start after it is warm like I posted earlier.
i would say its either a vacuum leak or a misrouted vacuum line. on my t2 i had the routing of the acv hoses wrong, once i fixed it, it wanted to start hot
mkie
mkie
Trending Topics
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
The1Sun
Sep 7, 2015 10:21 PM
