Installing a new flywheel
Old Sep 24, 2002 | 05:36 PM
hybridracer's Avatar
I Post In The Nude
Ok so lets say all you have is a hydralic jack, four jack stands, 2 friends, basic tools, and your hands. Do you think I could install a flywheel by myself? I could also have access to a tranny jack, hopefully.
Old Sep 24, 2002 | 05:44 PM
Silkworm's Avatar
Has been.. hangin' around
You're going to need an impact wrench to get the flywheel nut off. If you're going to do the pilot bearing, you'll need a pilot bearing puller.
otherwise, yes.
PaulC
Old Sep 24, 2002 | 05:47 PM
I Post In The Nude
and where would one go about aquiring a pilot bearing puller? and couldnt you use a breaker bar instead of an impact wrench?
Old Sep 24, 2002 | 05:53 PM
Silkworm's Avatar
1. you go to the autoparts store, and ask them for a pilot bearing puller.
2. Sure, if 1. you can generate 300ftlbs of torque with your breaker bar, while on your back under the car, and 2. you can find some way to keep the bloody engine from turning while you apply said 300 ftlbs of torque.
PaulC
osdesigns's Avatar
if you want to use a breaker bar, you will have to use about a 4 feet cheater bar (a jack handle). But using the impact gun is so much easier.
Old Sep 24, 2002 | 05:54 PM
osdesigns's Avatar
oh, you will also have to find a way to stop the flywheel/enine from turning with the breaker bar... ie, a mazda SST - flywheel stopper tool...
Old Sep 24, 2002 | 05:56 PM
Xentrix's Avatar
Kill Bear
Clicky here for bearing remover and other stuff...
The flywheel nut is a bitch. I watched a 3 foot cheater pipe break when my roommate was trying to remove it.
Old Sep 24, 2002 | 05:57 PM
I Post In The Nude
ah ok so where would said person (i.e me) get an impact wrench
Old Sep 24, 2002 | 06:01 PM
presetlimits's Avatar
you can either get an electric impact gun instead of having a compressor to use an air impact tool
Old Sep 24, 2002 | 06:12 PM
Silkworm's Avatar
Tool rental places, look them up in the phone book.
PaulC
Old Sep 24, 2002 | 06:39 PM
I Post In The Nude
Gracias
Old Sep 24, 2002 | 10:37 PM
zub
don't forget to rent that huge *** socket too. 2 1/8"
zub
whinin
Mar 30, 2019 07:53 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
