loud whistle sound while accelerating my car?????
Old Sep 23, 2002 | 08:50 PM
Dragonz818's Avatar
Question loud whistle sound while accelerating my car?????
This is the second time that I have had this happen. I cant seem to figure it out.
Its coming from the front left of my car while I am sitting in it. Basically directly in front of me. It sounds like a squeek but its not.
Like I have a leak in one of my lines and when I get on it hard it bleed through. I wouldnt know what that sounds like, but could that be it?
It has only happened twice. At first I thought it was in my suspension but its definately not.
Its just a quick pretty loud whistle or squeek that lasts a second.
Now I am thinking maybe a seal is getting ready to give and god I hope that isnt it.
Any Ideas Guys???
Old Sep 23, 2002 | 09:09 PM
try changing out your belts.
Old Sep 23, 2002 | 09:11 PM
it could also be one of the pullies or mabey the power steering pump. i know you said it wasnt a squeak but its just a thought.
Old Sep 23, 2002 | 09:24 PM
futurerexowner's Avatar
At what Rpm would you say it happened at?
Old Sep 23, 2002 | 09:28 PM
Dragonz818's Avatar
I would say right as 2nd turbo kicks on.
Old Sep 23, 2002 | 09:31 PM
Dragonz818's Avatar
Car still drives like it usually does no change in boost. Could be a belt but its suck a quick and random noise.
Sounds alot more like blowing through a straw with a hole in it. Not a squeek...
Old Sep 23, 2002 | 09:32 PM
Dragonz818's Avatar
My mods if it helps are. DP, MP, clutch, flywheel, bost / water gauge
I also noticed a small spiking but I am getting boost controller or pfc very soon..
Old Sep 23, 2002 | 11:27 PM
Dragonz818's Avatar
bump
Old Sep 24, 2002 | 12:56 AM
MAZDASPEEDFD's Avatar
I have that problem too. It squeeks every now and then when I punch it, but then again it does it even when I'm just cruising (could be a different noise). I also thought it was a suspension issue. Anybody got a clue of what is causing it?
Old Sep 24, 2002 | 01:06 AM
maxcooper's Avatar
WWFSMD
I used to get some kazoo-like noises right on the edge of making boost while cruising. I think it was just some kind of resonance in the intake tract somewhere. I haven't heard it for a while, but I changed a lot of the intake parts and I am not sure which change eliminated the problem.
-Max
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
alphawolff
Nov 17, 2015 05:57 PM
86glxNA
Aug 15, 2015 01:45 PM
