CBV verses BOV
Old Sep 23, 2002 | 06:41 PM
CBV verses BOV
I can't locate my CBV. I know it's on the aluminum tree ont he way to the intercooler but i can't find it...
how do I install a bov and how hard is it?
What is an atmospheric BOV... andr how are they installed and canI make one?
Old Sep 23, 2002 | 06:45 PM
RestoTII's Avatar
about the best pic i have right now is this one
http://www.geocities.com/njrhea/Box-Back.jpg
if the link doesn't work, click on it again, put a space before the web addy and hit enter. You can trace the brass check valve back to a metal one, then a hose makes a 90° angle to the metal branch you were talking about
Old Sep 23, 2002 | 06:50 PM
RestoTII's Avatar
just found another pic
http://www.geocities.com/njrhea/MyTII/TID_BOV.jpg
that shows where it connects to the branch better.
An aftermarket BOV shouldn't be hard to install if you get a kit. I've heard that some BOVs will fit the stock hose, but i'm not sure if you wanted it dangling off a hose. If you wanted to do the DIY mod, which alot of people swear against, then you just need a Check Valve like the one in my pic, and a hose to fit it. Then get a threaded nipple to fit the hose and check valve together and you're done. Mine still let a little vacuum leak, so I just tightened the spring a little. good luck
Old Sep 23, 2002 | 07:02 PM
Roy James's Avatar
My cars louder than yours
dont forget, to get those pics to work to click on the link, and then when it comes up as an error, to put a space before teh "http..." and then hit enter, and it'll reload the page error free.... yep.
Devon300zx
Sep 17, 2015 03:50 PM
zxrazorxz
Sep 14, 2015 07:21 PM
