Turbo Coolant Lines
Old Sep 23, 2002 | 09:39 AM
yzf-r1's Avatar
Turbo Coolant Lines
replaced the turbo coolant hoses along with the upper and lower radiator hoses, various other cooling lines, thermostat, and new PWR radiator over the weekend
after I took the turbo cooling lines out I split them open with a razor blade to have a look....I couldn't believe how decayed they were by the intense heat, the rubber was really thin and the interior of the lines was all blistered and flaking off.....I know they are almost ten years old, but my car only has 50k miles
all I can say is, if you have a higher mileage car with the stock hoses, you might want to consider getting them replaced, if they let go it could be bad news
it's kind of a PITA job but worth the peace of mind...the stock hoses (part# 13-5360-N3A1 & 13-54X0-N3A1) are pretty cheap....I'm not sure aftermarket hoses would fit without gettting kinked up....who knows
Old Sep 23, 2002 | 09:59 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Do you have a pic of the secondary one? I replaced the primary... But thats because it exploded. I need to do the rear one... Thanks!
Old Sep 23, 2002 | 10:04 AM
yzf-r1's Avatar
http://www.rx7turboturbo.com/robrobi...urbo_lines.htm
Old Sep 23, 2002 | 10:24 AM
rotary-tt's Avatar
2 babies - no back seats
I blew mine apart under hard acceleration. This should definately be added to the reliability maintenance of the cooling system along with:
New or aftermarket AST (or remove)
Checking operation of both cooling fans
Replacing all the other little cooling hoses to prevent fire on top of the motor.
Maybe replace the radiator for same reason as AST - plastic end tanks become brittle with age.
Old Sep 23, 2002 | 11:11 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Thanks!
7-sins's Avatar
thats not paint....
I replaced mine just a few weeks ago. One was leaking and the other was bad looking. Now I am prepping the coolant system for Evans coolant.
sYnth.
Aug 19, 2015 06:27 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Kyo
Aug 14, 2015 02:00 PM
