BAD hesatation at 5200, poor idle
Old Sep 22, 2002 | 11:38 PM
RangerJoeEOD's Avatar
I have a very bad hesation from 5200 to ilke 6000. Kill my ET. the car also dose not idle well, any thoughs its a S5 N/A
Old Sep 22, 2002 | 11:48 PM
Rotorific's Avatar
I dont know a damn thing
ever replace your fuel filter
Old Sep 23, 2002 | 08:40 PM
RETed's Avatar
TPS might be bad - too high resistance at WOT.
-Ted
Old Sep 23, 2002 | 09:53 PM
viperkiller7's Avatar
1.3 liters of whoop ass
What should it be at wot... my friends 87 is having problems... he was driving and the next thing he knew it was running like crap... sputtering like it wasnt gettin fuel and won't build boost.. half throttle its fine but as soon as you give it more to build boost it just sputters and bogs then it will boost for a split second then start sputtering again
Old Sep 23, 2002 | 10:34 PM
did fuel Filter a week or two ago. Whats a WOT.
Old Sep 23, 2002 | 11:18 PM
jacobcartmill's Avatar
just dont care.
ity should be under 5 kohms under wot.
Old Sep 23, 2002 | 11:33 PM
StarionX's Avatar
Pedal to the metal!
Old Sep 24, 2002 | 12:24 AM
Rotorific's Avatar
You measure the resistance of your tps at wide open throttle but really you turn your car to the on position and ohm out the tps and it should read 4k ohms and 1k at idle
Old Sep 24, 2002 | 12:26 AM
mintrx7's Avatar
Perhaps try some injector cleaner, possibly dirty injectors??
Rotorific's Avatar
Oh yeah dammit i too am having this same problem and its pissing me off it feels about as bad as the 3800 hesitation just at 5.5 to 6k and then it starts pulling again
Old Sep 24, 2002 | 12:38 AM
just dont care.
um.. this may sound like a cop-out solution, but is your 6pi working? i dont even know many details about this 6port induction because i have a T2, but i know that they open around that time (5500 rpms) just a thought...
Old Sep 24, 2002 | 12:42 AM
Rotorific's Avatar
i wish i could say i had that um cough "crap" cough but i dont have jack i ran premix for a while but i dont think dirty injectors are the problem it seems to be an electronic problem any ideas
Old Sep 24, 2002 | 12:50 AM
hmm try checking your tps make sure its on. and get some good injector cleaner
Old Sep 24, 2002 | 02:21 AM
von's Avatar
von
This is a strech here but Make sure your two acv lines are connected. The ones next to the tps somewere. then reset the ecu or something. Sometimes something changes and makes the ecu go crazy until you reset it. Pull the negitive then tap the brake 10 times then hold it for 30 seconds. Wait 15 minutes and it should be ready to go. This is not exactly the procedure but it works for me.
One day I disconected that acv port and split connector things or whatever they are , wile the car was idling. I took it for a spin and the car would hesitate badly around 4k all the way up... I connected them back on and the ecu never adjusted itself so it kept doing it until I reset the ECU. Give it a try . wouldnt hurt I guess.
Old Sep 24, 2002 | 04:46 PM
[QUOTE]Originally posted by mintrx7
Perhaps try some injector cleaner, possibly dirty injectors?? [QUOTE]
No thats been done, i will check the TPS tonight and reset the ECU. Any more sugg? I lover her but if it does not start behaving i will have to sell
Old Sep 25, 2002 | 01:46 AM
600HP CLUB's Avatar
i had this problem, when i first bought my car, the problem was the when i was boosting, the pressure from the boost was too much for the "pressure sensor" and caused it to bog, because it bogged from pressure, i bought a two tees to ease the boost, and yes, there is suppose to be a restrictor already in the vaccum line that connects the pressure sensor to intake manifold, about one inch away from manifold, but mines didn't have it so i made my own and whola, no more bucking.
This is for Turbo 87, i don't know about N/A's though.
-mike
rgordon1979
40
Mar 15, 2022 12:04 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
Frisky Arab
Sep 4, 2015 06:17 PM
