Max that the stock feul rail will hold?
Old Sep 20, 2002 | 01:19 PM
jreynish's Avatar
New Project on the Way...
I want to know what the maximum the stock feul rails in a S5 TII will hold. Yes they will be controlled not sure what but i want to put 4 820cc injectors is this duable? witht he stock rails? i need lots more feul for my T04 and well i am trying to make a shopping list for what i will need when i put my car back together! Any tips hints or advice?
Old Sep 20, 2002 | 01:50 PM
darkwaveboi's Avatar
Need donor car in Fairfax
im not completely sure but i think 720 or 800 are the max...
Old Sep 20, 2002 | 03:10 PM
DaleClark's Avatar
RX-7 Bad Ass
Many Haltech guys use 550cc primaries and 1600cc secondaries.
I don't know at what point the stock fuel rails become a problem. That's what fuel pressure gauges are for . Probably somewhere north of 400hp would be my guess.
Dale
Old Sep 20, 2002 | 11:56 PM
jreynish's Avatar
well i Need at least 800cc in both primaries and secondaries! and i do not have a haltech as i cannot afford it! and i do not have a stock turbo to put back onto my car! so I Am looking at the Greddy e-manage and 820cc is the biggest i can put in! so i figured that i would ask if anybody knew what the max that the stock feul rails would handle. So if anybody knows let me know!
Old Sep 20, 2002 | 11:57 PM
jreynish's Avatar
oh sorry and i will be running somewhere in the region of 400-450hp by the time i am done!
Old Sep 21, 2002 | 01:03 AM
RETed's Avatar
500hp is about the limit.&nbsp I would worry about the 5/16" hard metal fuel lines more than the fuel rails itself...
-Ted
Old Sep 21, 2002 | 10:05 PM
jreynish's Avatar
Care to elaborate? Because i need to know! so i can put like 820cc in both the primaries and secondaries? and it will work? but what is this about the feul lines you speak of?
Old Sep 23, 2002 | 09:24 PM
RETed's Avatar
The car uses 5/16" hard metal lines from the gas tank to the front before the fuel filter.&nbsp I recommend changing them to min -6 AN SS lines if you're shooting over 500hp from the engine.
For your application, the stock stuff sounds fine.
-Ted
Old Sep 23, 2002 | 11:32 PM
Scott 89t2's Avatar
SOLD THE RX-7!
on stock ecu?
but as for injectors.. I don't know of anything that size. lots use 720's in the stock rails. the 1600's need to have the rail modified to fit them. I don't know of anything inbetween that will fit in the stock rails..
Old Sep 23, 2002 | 11:57 PM
Rpeck's Avatar
What R U thinking self?
I have 1000cc Secondaries in my stock secondary rails. I had a set of stock 550cc injectors inlarged so i would not have to deal with the impeadance factor, my injectors are high imp. Hard to find them in a large format. I use a S-AFC ... so with +50 being max, i wanted some tuning room so i went 1000, instead of 1100.
Old Sep 24, 2002 | 12:11 AM
Scott 89t2's Avatar
SOLD THE RX-7!
wow they made them from 550 to 1000? was that at RC ? I was thinking about doing something like that since there are no bolt in's for the S5's...
Old Sep 24, 2002 | 12:15 AM
Rpeck's Avatar
Yup it was RC, they said they can usally go %50 over. that would put them max at 1100, but like I said I wanted some tuneabilty so i stopped at 1000. Or else I would have to set the S-AFC at max, and have nothing to work with.
NOT cheap though. $180 per injector! but nothing considering the gains.. and all the other money i spend on this thing ... you know what I mean
immanuel__7
89
Sep 5, 2015 10:23 AM
Snook
Aug 15, 2015 08:18 AM
Alan777
Aug 13, 2015 02:47 AM
