turbo II or cosmo block? which one is better?
Old Sep 20, 2002 | 10:04 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
I am gathering parts for my engine swap. I have my TII tranny and my new 13b header. and a atkins 7in supercharger will be comming soon.
I have decided to run the a low compression engine.
But I was wondering. should I go with a TII block or a cosmo block.
I have heard the cosmo has better port timing.
what makes the cosmo block better? and is it harder to swap than a TII block?
Old Sep 20, 2002 | 10:08 AM
Directfreak's Avatar
I am a Jeeper Now.
A cosmo block is basically and improved REW (third Gen engine) with less hassles on installing into a FB than an FD engine.
They are thicker near the dowels, have improved oiling and cooling, and much better port sizing than than old 13BT.
Old Sep 20, 2002 | 10:27 AM
zyounker's Avatar
root
Um i think the RE pre-dates the REW, but it should be better then a S4 TII. The S5 TII is also thicker near the dowels..
I have read there is almost 0 difference between the S5 TII block and the RE and REW besides ports. So if you port a S5 block it will be nearly identical..
And any of the block bolt right into a 1st gen if you change out the oil pan and front cover..
-Zach
Old Sep 20, 2002 | 10:28 AM
What about my oil cooler lines.
Will they work on both engines?
and I would have to bolt on my 12a front cover and get a RB engine mount right?
Old Sep 20, 2002 | 10:30 AM
I dont plan on rebuillding the motor when I get it so better ports are important.
how much of a HP difference would there be, at, lets say 10lbs of boost.
Old Sep 20, 2002 | 10:33 AM
zyounker's Avatar
root
Well, you need to realize the S4 & S5 blocks come with a single turbo and the S5 has a better turbo.
Now the REW and RE engines come with twins..
The RE & REW would have to be converted to run in non-seq.
If you don't plan on building the engine, and keeping whatever turbos it comes with i would go with the 13B RE.
-Zach
zyounker's Avatar
root
BTW the REW is probably better, but costs alot more too..
-Zach
Old Sep 20, 2002 | 10:40 AM
I am a Jeeper Now.
Here are the differences between the 13BT and 13BREW (and RE) engines.
He wanted to run a supercharger anyway, so he won't need the twins.
Up to about 400 HP, just about any 13B block will do.
Porting will equalize any advantages any one engine's port sizing has over another. Once you go with Higher HP (400+), you want the beefier cast RE and REW, especially if you're gonna dowel pin the engine.
A Supercharger won't get you to 400HP on a rotary anyway. So just get the newest, least milage one you can get, since you're not rebuilding it or porting and you should be fine.
Old Sep 20, 2002 | 10:41 AM
i am not going to use anything but the block. I am going to run a atkins 7in. so the turbos, manifolds, TB, sequencial doesnt matter.
just the differences in the block.
I am leaning tward a TII block because of cost and availanbility.
Old Sep 20, 2002 | 10:43 AM
zyounker's Avatar
root
I would opt for the S5 block, but an S4 block would suit you just fine..
And be a little cheaper..
-Zach
Old Sep 20, 2002 | 10:46 AM
yeh just the block.
I will probably never exceede 15psi.
I have been looking and buying a jspec engine from cork and parting out everthing I dont need.
Old Sep 20, 2002 | 10:49 AM
zyounker's Avatar
root
Um, i think cork is a little pricey, how much do they want for a TII block
Usually S4's go for ~$550 and S5's go for ~$750..
There are tons of engine imports, check around..
-Zach
Old Sep 20, 2002 | 11:04 AM
damn, they want like $900 for a s4 and 1100 for a s5
they do a bunch of tests on them but that seams pricy.
Anyone want to recomend a importer?
or have a block to sell.
Old Sep 20, 2002 | 11:25 AM
zyounker's Avatar
root
Check these:
http://www.nippon-motors.com (750-950)
http://www.jspecjdm.net (call)
And i thought teamfc3s.org use to sell engines, but can't find the info..
-Zach
Old Sep 20, 2002 | 12:31 PM
David88vert's Avatar
r71's daddy
C&T International
Do a search.
Old Sep 20, 2002 | 12:57 PM
rx7gslse's Avatar
EX Pres of DFW Drunks
www.cntintl.com
friend of mine oders lots fo stuff from them for racing and swears by them
Old Sep 20, 2002 | 12:58 PM
rx7gslse's Avatar
doh!
http://www.ctintl.com/
Old Sep 20, 2002 | 01:15 PM
Jeff20B's Avatar
Lapping = Fapping
Speaking of a 7", my friend and I just installed one in his REPU that has a GSL-SE engine in it. 9.4:1 rotors. I wonder how long the SE engine will last
Old Sep 20, 2002 | 03:26 PM
I just saw something, s4 use mechanical oil sending units, and s5 use electrical, I planed on running premix so would a s4 work better. Or wouldnt that matter.
I am leaning tward s4 becuase I dont care for the better turbo or manifold
Old Sep 20, 2002 | 03:29 PM
I am a Jeeper Now.
You need to use a 12A or GSL-SE Front cover anyway.
Those have mechanical Oil Injection pumps.
That's what I am using on my Cosmo engine as well.
Old Sep 20, 2002 | 04:09 PM
zyounker's Avatar
root
It doesn't matter what OMP it had.. just block it off or convert it (either one) to RPM based..
-Zach
Old Sep 20, 2002 | 04:22 PM
diabolical1's Avatar
one question here ... and i've never used or worked with a supercharger, so i may be a bit ignorant - so forgive me, but ...
wouldn't you want the higher compression ratio of the S5 13B-T for better streetability, since your boost will now be RPM-based, instead of exhaust-based?
try the Gen II forum and see how much boost the 9.4 rotors can take ... i don't know, but i was thinking that though i agree you'd want to have lower compression for higher boost levels, i'm just wondering if the turbo 13B's have enough to keep you happy on the street.
Old Sep 20, 2002 | 11:26 PM
Jeff20B's Avatar
Lapping = Fapping
Personally, I'd rather supercharge with 9.2 or 9.0 rotors, but a GSL-SE engine is what the truck already had in it.
Old Sep 20, 2002 | 11:44 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
yeh just the block.
I orginally called corksport and they acted like I was a ******* moron, and I was a looser with no money. I asked questions, they were like yes/no answers and he didnt really have any thing to add to it. I also told him I would like a picture of what I was buying, he never sent one, they called me back 3 freakin' months later and I let em have it... You want a rotary engine WITH a warranty? That it will have compression when you try it when you get it? www.fc3s.org and talk to dave or joe.. Thats were me and setzep got ours from, you wont be sorry
Old Sep 21, 2002 | 08:12 PM
THe TII motor is built for boost, and I can spin the charger faster to make up for the lower compression.
cristoDathird
28
May 30, 2019 08:47 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
