aobut the 5th and 6th ports.
yes, i know this subject has been beaten to death. But how do you know that your ports are opening from normal everyday driving? I have no air pump, or cats. But the vaccum hose, is connected to a nipple on the race pipe.
And the car pulls harder then before sounds a hell of a lot better, if the ports aren't opening...What am i missing?
Evan
Evan
what year is your car? i think 88 and earlyer ones work differently then the later ones. Every one says to smear white lithum grease (cuz its ez to see?) on the actuators, then go drive around and make sure to take it up to red line. then see if the grease has moved on the actuators, if its not, they arnt opening.
While you have the car in idle use the throttle lever on the throttle body. Slam it down really fast all the way and then release so as not to blow your engine. If they work you should see them open.
Originally posted by DC350
ohh, okay thanks man! yeah, i uses back pressude, not VDI
it's an 87, thanks!
it's an 87, thanks!
Also, I'm darned near positive there has to be a load on the engine for the ports to open (I know this is true on S5s). Therefore, revving the engine in the driveway is not going to open the ports.
MILOS7
Oct 9, 2015 02:19 AM
23Racer
Race Car Tech
Sep 21, 2015 10:48 AM
