13B re?????
Old Sep 18, 2002 | 02:23 PM
VetteKiller's Avatar
talk to cymfc3s
Old Sep 18, 2002 | 02:31 PM
RETed's Avatar
Small primary ports - probably smallest out of 13BT and 13B-REW.
Largest secondary ports - probably biggest out of 13BT and 13B-REW.
The 13B-REW probably have the biggest port area if you take both primary and secondary intake ports together.
Cosmo engines (13B-RE and 20B) have better (rear) stat gear bearings (i.e. 3-window) versus 13BT.&nbsp Arguably not as good as the 13B-REW 9-window bearings.
Cosmo engines run 9.0:1 CR's, which is the same as the Kouki 13BT and 13B-REW engines.
13B-REW has the highest oil pressure stock - around 100psi.
My observations - the Cosmo (and 13BT) have better intake manifold design for high RPM power.&nbsp The 13B-REW longer runners for more for low and mid range power - the large butterflies on the TB make up a little for the long intake paths, but this is still not the "optimum" design for high RPM power.
The 13B-REW is still a superior motor, IMHO.&nbsp It is the last "13B" motor Mazda has produced, so it should have all the latest enhancements (i.e. large combined intake ports, higher oil pressure, deeper oil grooves, etc.).
The Cosmo motors, especially the 13B-RE is an attractive option to drop into an FC.&nbsp There a couple of verndors that sell pre-made engine mounts that allow drop-in installs of the engine block itself.
-Ted
Old Sep 18, 2002 | 05:59 PM
Ok My engine is 13Bt Primary plate,13B-Rew Housings and 13B-Re Secondrys.
I hav'nt had it running yet so i cant tell you how it goes but i know i had quite a job geting a set of Re secondry plates.
To date the list of Mods (engine alone) are
Extended Port 13bt Primarys
Bridge Ported 13bre Secondrys
Ported 13brew Housings
Clearanced 13brew Rotors + 2pc 2mm apex tips
80psi Regulator
Hardened Staitionry gears + Window bearings
Thermo Pellet Mod
Sump Baffle plate
Omp 2 Stroke Mod
I thinks thats it?
I would like to point out i had to mod the Inlet Manifold to fit the Re plates correctly.
Old Sep 18, 2002 | 07:26 PM
RETed's Avatar
That's some set-up!
-Ted
Old Sep 19, 2002 | 12:01 PM
Thanks.
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Robrods64
Oct 2, 2015 07:56 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
