I need a TID adapter anyone got Specs?
Old Sep 18, 2002 | 12:19 PM
Rpeck's Avatar
What R U thinking self?
I have a stage 3 Turbo Hybrid upgrade from BNR
http://www.lourdsmusic.com/bnrsupercars/turbo8788.htm
And I have to hook-up my stock TID to it for the time being to pass smog. Anyone know what size adapter I need to go from the end of the stock TID to the Above listed Hybrid Turbo?
Also any good sugestions on what to use to hook it up, clamp it Etc. If I clamp rubber onto Rummer I wont be able to get it very tight it will just crush/bend ... if you know what I mean. Maybee I can put somthing inside the stock end ... like a metal bearing lookinh thing to hold it solid?? I am sure someone has done this before? It's only gotta last about 2 weeks then I will put my new TID and air cleaner on.
Thanks alot for any info.
Robert
Old Sep 18, 2002 | 01:25 PM
Scott 89t2's Avatar
SOLD THE RX-7!
even if you get something to fit. it's gona push the stock TID a couple inchs out... won't fit to the stock box.
you need it for a visual? as long as the vac lines are hooked up to the TID I couldn't see how there would be a problem... but cali is kinda gay so who knows
Old Sep 18, 2002 | 03:10 PM
Rpeck's Avatar
Ya, I need it for a visual and for the lines that come off it. I can cut the extra 2 inches off the stock TID with a razor blade... I won't need it for anything else.
Old Sep 18, 2002 | 03:18 PM
Scott 89t2's Avatar
SOLD THE RX-7!
well just mesure it LOL.. cut the stock one down so it's 3" or so. then add a couple inches of 3" metal pipe. clamp the stock TID onto the metal, and clamp the metal to the turbo using your TID silicon connecter.
or leave the TID as is, get some 2.5" pipe. and then you'd need a 2.5" to 3" redcuer to attach to the turbo, or whatever size your turbo is on the outside.
you can get black connecters from http://www.roadraceengineering.com/hoseandclamps.htm if that makes it any easier. might not want a red one in there.
site looks down right now...
Old Sep 18, 2002 | 04:40 PM
Rpeck's Avatar
Thanks Smartass ... I know that, but its a bitch to get to .. and right now I am work. It's the last thing I need to start this **** up after 8 months of working on it. I was hoping someone knew the specs off hand so i could make some phone calls while I'm at work and see if I can get one local on my way home... and fire this thing up tonight! Thanks for the site though .. i will order it from there if I can't locate one today. I'm sick of waiting!!
I figured this would be a easy question .. All the T04 hybrids around .. and the size of the stock TID ... I guess not
Old Sep 18, 2002 | 04:52 PM
Scott 89t2's Avatar
SOLD THE RX-7!
the stock one is just under 2.5"
Old Sep 20, 2002 | 11:31 AM
Rpeck's Avatar
Okay i figure I need a pipe or somthing hard to connect the 2 ends right? What can i do to prevent sucking this conector pipe into the turbo? ... um? what are the chances of that? how mch sucktion to these things have?
cewrx7r1
15
Aug 6, 2018 11:41 AM
ZacMan
Sep 19, 2015 09:20 PM
