quick question
Old Sep 18, 2002 | 11:47 AM
osiris7's Avatar
Question quick question
quick question,could the 3800rpm stumble be removed if you simply replace the cars ECU??i have a 87 N/A..
Old Sep 18, 2002 | 12:58 PM
Snrub's Avatar
Probably not, but I've heard of someone trying it before. For me it was the TPS. Grounding things is another possible solution.
Old Sep 18, 2002 | 02:58 PM
osiris7's Avatar
you said grounding things, could you tell me where the major grounds are located??thanx in advance
Old Sep 18, 2002 | 03:28 PM
Aaron Cake's Avatar
Engine, Not Motor
Maybe, maybe not. The hesitation is usually caused by TPS or ground problems. Try a search on "grounding" and "3800 rpm hesitation". It's been covered more times then I can count.
Old Sep 18, 2002 | 03:59 PM
Snrub's Avatar
Do this step first, it's less work and probably more likely.
TPS: http://fc3s-pro.com/TECH/HOWTO/TPS/tps.html
While you're at it compare to spec the resistances of the crank angle sensor, solenoid resistor pack, AFM, injectors....that's all I can think of at the moment. Your injectors could be clogged as well, getting them clean and balanced or replaced is another option.
Grounding: http://www.teamfc3s.org/faq/FAQ.html#s23800
For grounding you could do the boost/pressure, ECU grounds for the injectors, -ve battery terminal, engine grounds, TPS ground and if you want the grounds on the injector harnesses.
A clogged cat could be another possiblity.
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
