Twirling Shifter!
Old Sep 18, 2002 | 11:36 AM
NixxoN's Avatar
Twirling Shifter!
Does anyone know exactly what it means when your entire shifter can turn around in circles repetedly... and what it would take to fix? It's annoying to all of a suden notice that your shifter as turned a 360 degree turn and feels realy funny too.
Old Sep 18, 2002 | 11:39 AM
AreExSeven's Avatar
Huh?
You sure its the whole shifter and not just the ****?
Cause for the entire shifter to turn, it would either have to be unbolted from the tranny, or the shifter arm would have had to somehow broken off of the mount and be free within that.
Pull up the rubber boots around the shifter, and check to make sure there are 3 bolts holding it tight to the tranny below.
Old Sep 18, 2002 | 11:41 AM
do you have a short shifter?
Old Sep 18, 2002 | 11:46 AM
NixxoN's Avatar
Well the ****, and the metal that it is attached to is spinning.
NixxoN's Avatar
I did change my shifter bushings latly, maby I forgot to attach those bolts again... but assuming those bolts are still there, what else could be wrong? Someone once told me that I might ahve to drop my transmission to fix this.
Old Sep 18, 2002 | 11:48 AM
AreExSeven's Avatar
Huh?
I see no reason you would have to do that. You can reach it just fine with the tranny in place.
But while you are replacing your transmission that ran dry cause you left the speedo cable out, you can fix this
Old Sep 18, 2002 | 12:04 PM
NixxoN's Avatar
hahaha aight, sounds good
Old Sep 18, 2002 | 12:44 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
When you installed the bushings for the shifter, did you line the slot in the shifter up with the pin in the transmission? It's at the front, and that pin has to engage to prevent this and for it to really shift properly.
Brad
Old Sep 18, 2002 | 12:49 PM
OC_'s Avatar
OC_
I'm bastardizing my car!
yea, if the pin the pivot ball on the shifter rides in some how breaks off or is not lined up, im sure the shifter would be able to spin around freely like you discribe.
Old Sep 18, 2002 | 01:00 PM
NixxoN's Avatar
Pin on the shifter ball? uh oh... I don't remember any pins on the shifter ball infact I think I remember a place for there to be a pin sticking out on the ball but ther eboting nothing sticking off it.
Old Sep 18, 2002 | 01:02 PM
Icemark's Avatar
There is a rubber isolation layer between the lower shifter and upper shifter shaft (the part that the **** screws onto). I bet that the upper shafter shaft has broken free of the rubberised isolation layer that is between the lower shifter and the handle.
Unless there is a short shift kit or he has a broken guide rod on the tranny's shifter hole, I doubt he could have installed the shift **** assembly without lineing it up. To top that off the inner boot would have to be all torn up to allow the whole assembly to rotate.
Old Sep 18, 2002 | 01:31 PM
NixxoN's Avatar
Yeeep innner boot torn up, missing a pin.... SHIFTER GOES WEEEEE!
So all I really need to fix it is anew shifter right?
Old Sep 18, 2002 | 02:43 PM
NixxoN's Avatar
Oh and anew inner boot?
Old Sep 18, 2002 | 02:58 PM
rx7_ragtop's Avatar
The pin is not on the shifter, it is on the inside of the housing where the shifter goes in- about halfway up between the 2 bushings. You have to angle the lower bushing in to get it under this pin. It fits into a slot in the front side of the "bulge" that the 2 plastic bushings fit around on the shifter. If this is missing you would probably have to replace the whole shifter housing/shift rod on top of the tailshaft housing to fix it.
Brad
Old Sep 18, 2002 | 04:00 PM
i have tha same problem and my shifts are kinda longer now i took the shifter out and didnt even put the roung bushing back on.. it was busted anyway grrr
Old Sep 18, 2002 | 08:04 PM
NixxoN's Avatar
Since I have no clue in hell what you guys are talking about, I choose to instead post pictures :P
Old Sep 18, 2002 | 08:06 PM
NixxoN's Avatar
coughs
NixxoN's Avatar
coughs
Old Sep 18, 2002 | 08:07 PM
NixxoN's Avatar
Yeeep
Old Sep 18, 2002 | 08:08 PM
NixxoN's Avatar
I's bee reconnin
Old Sep 18, 2002 | 08:10 PM
NixxoN's Avatar
dum dee dooo dummmm
Old Sep 18, 2002 | 08:11 PM
NixxoN's Avatar
Missed one!
Old Sep 18, 2002 | 08:12 PM
NixxoN's Avatar
back on track! sorta
Old Sep 18, 2002 | 08:13 PM
NixxoN's Avatar
Rollin Rollin Rollin
Old Sep 18, 2002 | 08:15 PM
NixxoN's Avatar
Is there really an easier way to do this? I always wondered...
