Haltech with J&S Safeguard?
Old Sep 17, 2002 | 10:51 AM
Directfreak's Avatar
I am a Jeeper Now.
CROSSPOST FROM THE HALTECH FORUM
Originally posted by gmonsen
hi, jay. i don;t think knock sensing works very well. certainly not as part of a separate system. when i first installed the haltech, i still had the j&s installed. it would retard the damned timing whenever it detected knock and meanwhile, the haltech was retarding it based, i think, on intake temps. it got screwy. i think the best thing to dpo relative to knock is just to tune it right with the wideband and perhaps install water injection.
anway, i'm looking for info on what, if anything the haltech does on its own to change timing, if anything? anybody know anything here? there's a correction map for inlet air temp correction and one for coolant temps.
the reason i'm asking this is that when i am dynoing and the amibient air temps are high (100+) and the intake air temp goes over 140, my timing seems to retard a good bit. anybody want to talk about this? thanks. gordon
Gordon, I have an E6K and a J&S. I still haven't installed them since I am in the mddle of my Cosmo engine swap in my 1st Gen.
Is it possible - To wire in the J&S on the OUTPUT side of the Haltech, between the Haltech and the MSD6AL so that the knock sensor will retard timing upon knock, without it having to go through the Haltech?
From the thread above, it seems that we can't use the J&S with the Haltech on the INPUT side because of the slow response.
Please provide any info you, (or the other Haltech knowledgable guys) may have on this.
Before I get flamed, - I already have the J&S, so I want to use it. It is not just a case of engine tuning 101, so I don't need to hear that "you don't need the J&S" by everyone.
Thanks in advance.
Old Sep 18, 2002 | 01:55 PM
fastrotaries's Avatar
W. TX chirpin Monkey
yeah.......it's a little extra insurance in my book
Old Sep 18, 2002 | 05:12 PM
RETed's Avatar
I'd like to hear how you guys are changing the trailing spark at the same time the J&S starts to pull back timing on the leadings for this to work.&nbsp It certainly does NOT work effectively with the stock ignition system...
-Ted
Old Oct 11, 2002 | 02:16 AM
Flyrx7's Avatar
Money Pit
-Ted
Brings up a question I've been looking for an answer on. What system out there retards both the leading and the trailing? Does anyone know how well the knock control on the AEM ECU works?
Frank
Old Oct 13, 2002 | 10:14 PM
I am a Jeeper Now.
Frank
I got the info straight from J&S. According to them, it doesn't need to retard the trailing. I had to send my box back to them for them to upgrade it to trigger the MSD6AL's between my Haltech and the TII coils on my Cosmo RE.
Old Oct 17, 2002 | 03:49 AM
Nathan Kwok's Avatar
I'd like to hear why it doesn't need to retard the trailing, because detonation often occurs on the trailing side too. Wish I knew that before I bought it...
Old May 13, 2006 | 11:27 PM
Villision_Motorsports's Avatar
hEeL To ToE MoFo!
Bringing up very old news any follow ups on this from anyone im looking at this unit to work with my microtech!!
Old May 14, 2006 | 02:06 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
perhaps i can be of some help Mike.
i am about a week from firing up my fd w lots of new mods, among them a J&S. i will be running pump and methanol and the buick guys tune their turbo'd systems by primarily using knock. i did some research on the J&S unit and eventually talked to the guy who created it... v knowledgable.
based on my research it is on my car and i expect to get great use out of it.
the current J&S can only retard the leading plugs. it can retard up to a maximum of 20 or 10 or 5 degrees depending on settings. since we generally run a maximum split of 14 degrees and it is essential that the lead not fire after the trail you would not run the 20 degree setting.
the newer versions have a boost port. IMO this is essential since it allows the unit to not retard until X boost. the reason this is important is we often run zero split in the vacuum portion of the map and if the unit retarded the lead it would be firing after the trail.
i run a Power FC and have no conflict issues w the J&S since the Power FC does not actively retard timing re to knock.
i suspect that the J&S will be of significant help to me this year.
howard coleman
Old May 14, 2006 | 10:15 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
i have one, but i'm using sequential ignition. i'm debating on whether to sell it or get another one and use both.
