Suddenly won't start
Old Sep 16, 2002 | 06:39 PM
79rx7's Avatar
Newbie
Unhappy Suddenly won't start
All of a sudden, my 79 RX-7 would not start this morning. It's completely stock, 51,000 miles, and I've never had any starting problems. When the starter is engaged, it fires and acts like it'll run fine. But as soon as I release the key to disengage the starter, it dies.
Any ideas?
Thanks,
Rich
Old Sep 17, 2002 | 07:38 PM
paposwing14's Avatar
Is your pump working have you checked the filter I have somewhat same problem take you plugs out hit them up with wire brush and crank it !
Old Sep 17, 2002 | 07:42 PM
Spieder's Avatar
I think the 79's have points, check to make sure one isn't broken or closed.
Old Sep 17, 2002 | 08:23 PM
82mazdarx7's Avatar
Im Rick James Bitch
Yea check the fuel pump and make sure the fuel filter is not clogged. Other than that ???
Old Sep 17, 2002 | 09:13 PM
79rx7's Avatar
Newbie
Thanks for all the hints, guys. I found the problem. I had an intermittent fuse. I replaced it yesterday, but apparently the one I put in had corroded ends from sitting around so long. All is fine once again.
Thanks,
Rich
Old Sep 18, 2002 | 12:54 AM
Sammymatik's Avatar
79 have points? Hmmmm someone must have swaped my motor at some point with a later model...
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
Im faster
Aug 19, 2015 02:57 PM
