Sponsored by: CARiD
interchange rotors?????
Old Jul 24, 2001 | 11:03 PM
RxSeven1's Avatar
if i had 2 engines could i intercange the rotors if i had a bad one????how about the rotor with the housing
Old Jul 25, 2001 | 05:34 AM
MAZMAN's Avatar
yes,but they should be balanced
Old Jul 25, 2001 | 05:51 AM
daveRX-3's Avatar
Thumbs up rotors
The rotors are coded with letters, you can combine them as long as it's the same letter or no more than one letter either way, ei: a rotor coded "C" can be matched with another with D or B code, an A rotor can only be matched with another A or a B one, a B one will work with an A or C rotor. As for the housings as long as they are usable and for the same engine (12A or 13B) there should be no problem.
Old Jul 25, 2001 | 09:21 PM
IGY's Avatar
IGY
Don't forget to change the rotor bearings. I've seen some pretty nasty bearings from rotors and stationary gears from changing things around. I have in my motor now, a front rotor from another motor in the rear of my motor, all I did was put in a new bearing. On top of that I have a front rotor housing in the rear and a rear rotor housing in the front.
Old Jul 26, 2001 | 08:24 PM
RxSeven1's Avatar
how long would the engine last like that?
Old Jul 27, 2001 | 12:52 AM
IGY's Avatar
IGY
Just as long as any other rebuild.
Old Jul 27, 2001 | 02:05 AM
maxcooper's Avatar
WWFSMD
Can you be more specific about the type (12A, 13B, turbo?) and years of the engines? The rotor weights changed over the years.
Here's some info about the weights and compression:
http://www.mazdatrix.com/faq/rotorwgt.htm
You need to have the rotors, flywheel/rear counterweight, and front counterweight match to avoid major imbalance.
-Max
ZacMan
Sep 19, 2015 09:20 PM
BUSTN
V-8 Powered RX-7's
Sep 2, 2015 04:39 PM
