How do i remove this peice?
Old Sep 15, 2002 | 05:12 PM
Rs4Racer's Avatar
Hey guys I want to remove the peice of metal where the speakers are bolted onto and its right above the shocks. you have to cut a hole in it to put strut bars on but i want to get rid of it. how should i go about taking it off?
Old Sep 15, 2002 | 05:13 PM
Rs4Racer's Avatar
Old Sep 15, 2002 | 05:18 PM
SLOWT2's Avatar
From: new hampshire, middleton(a town so small we have no conveince stores)
cut cut cut cut, find a freind that has a plasma cutter and go town on the speaker tower.
-joe
Old Sep 15, 2002 | 05:21 PM
banzaitoyota's Avatar
What Subscription?
PLASMA CUTTERS ROCK!!!!
I have a Drag-n-cut!
Old Sep 16, 2002 | 12:54 AM
Rs4Racer's Avatar
ah well since i dont know anyone with a plasma cutter i just went and got a screwdriver a hammer and a hacksaw.
so far i got one side off without any problems.
Old Sep 16, 2002 | 01:24 AM
Rotorific's Avatar
I dont know a damn thing
just go to a machine shop and they will do it for you for a little cash any c&c shop will do it
Old Sep 17, 2002 | 10:11 AM
FPrep2ndGenRX7's Avatar
Drill out the factory spot welds. Its alot cleaner looking than hacking it off with a saw or plasma cutter. It may take a little longer but its worth it to do it right. If you drill to far you can easily do a little body work on it or spot weld the holes up and grind it flat. At which point it will need priming and painting. But if you want to get it off quick just use the plasma cutter. I haven't removed mine yet since I'm going to mount the rear strut bar brace to the unused factory seat belt mounts. I'll mount my harness to the strut bar. When I add the roll cage I'll remove them at that time.
Old Sep 17, 2002 | 10:34 AM
Jimmy325i's Avatar
No longer cares
Air chisel or hammer and chisel is the way to go. Just go at the spot welds at a very flat angle (so you don't go through the panel) This will allow you to remove the entire piece without putting any holes in the wheel well sheet metal or burning your interior out from sparks.
I lost about 3lbs a piece from removing these. (also did it for strut bar installation)
Old Sep 17, 2002 | 12:30 PM
Morbius's Avatar
I did the removal yesterday. Used tin snips and a metal chisel to get it out. Just takes some time and a little grinding for clean up. I had the backglass and seats out so there was alot of room to work though.
-Morbius
Old Sep 17, 2002 | 01:29 PM
Silkworm's Avatar
Has been.. hangin' around
Actually, a spot weld cutter is the way to go It's like 10 bucks at the auto paint/body shop supply store
Makes quick work of those pieces.
PaulC
Old Sep 17, 2002 | 03:05 PM
Rs4Racer's Avatar
PaulC
lol i wish i would have know about that yesterday..
with a chisel hammer and hacksaw it took me about 2 hours a peice... i was kinda goofin off too.
i thought the strut bar mounts onto the same holes as the upper strut mounts? did you have that custom made?
Old Sep 17, 2002 | 08:56 PM
Jimmy325i's Avatar
No longer cares
Kinda... I made it myself.
The metal is actually two layers thick in that spot so the re-enforcement plate under it is actually well anchored. The bar is preloaded as well because of the ability to tension it while tightening the mounts.
Old Sep 18, 2002 | 01:39 AM
HIMNI Racing's Avatar
Rick James
you could always use a good shot gun. ha,ha i don't know
Old Sep 18, 2002 | 08:57 AM
I think I like Jimmy325i version better than mine. I've got an air chisel, some bits and a air compressor. I might have to try that this weekend.
Jimmy - Nice rear strut bar.
Old Sep 18, 2002 | 09:47 AM
darkwaveboi's Avatar
Need donor car in Fairfax
where do you mount the rear speakers when you take the shock towers out
Old Sep 18, 2002 | 09:53 AM
Morbius's Avatar
Whats a stereo.....I want to hear just exhaust sounds when i'm done stripping the car
-Morbius
Old Sep 18, 2002 | 10:33 AM
Jimmy325i's Avatar
No longer cares
Fprep, Thanks. I was using a new roll of wire in my welder that I couldn't get to penetrate for **** untill I turned the feed rate to warp speed, so the welds on the mounts look like *** but they're plenty strong. Like my welding teacher taught us... Gorrilla Ugly = unbreakable.
For a proper sound stage you really don't need rear speakers. I don't do quality stereos in cars anymore,(out grew my income for that hobby) and I have to use an ear bud to hear my 2-way as it is. (gotta love 2.5" open exhaust!)
Erosangel
Sep 18, 2015 04:06 PM
Steelwheelz
Sep 15, 2015 03:22 PM
