Finished non-seq and only 1psi to redline
Old Sep 15, 2002 | 10:20 AM
adamrx7's Avatar
OG
I just finished my non-seq conversion and only 1psi to redline. I did every thing like the "rikky" site and other sites. I also took the metal bird's nest out. I've had boost problems before, but i thought they would be gone after the conversion.
I would like to thank ejmack for all his help yesterday
Old Sep 15, 2002 | 10:43 AM
adamrx7's Avatar
OG
Just put new couplings on yesterday
Old Sep 15, 2002 | 11:26 AM
adamrx7's Avatar
OG
WE tried getting boost by using a manual boost controller but still 1psi.
Old Sep 15, 2002 | 12:13 PM
spooledUP7's Avatar
There and back again
Maybe you have kentucky fried turbos like I did. What kind of play do you have in your turbos? Have you checked to see that they spin well/easily?
Old Sep 15, 2002 | 12:20 PM
adamrx7's Avatar
OG
turbo's are fine.
Old Sep 15, 2002 | 12:32 PM
adamrx7's Avatar
OG
I use to get 10 psi in the first turbo and like 6 in the secound
Old Sep 15, 2002 | 01:14 PM
adamrx7's Avatar
OG
I have the door open twards the fronf of the car
Old Sep 15, 2002 | 01:22 PM
7-sins's Avatar
thats not paint....
Maybe you hooked up the CRV and ABV (blow off valves) wrong, they are suppost to both be on the vacuum nipple comming from the upper intake manifold. Do you actually hear the woosh like you would with a boost leak? What RPM range do you see the 1psi at and what are your mods?
Old Sep 15, 2002 | 01:25 PM
adamrx7's Avatar
OG
even if the door was closed i would see some boost from the first turbo working would'nt I?
Old Sep 15, 2002 | 01:27 PM
adamrx7's Avatar
OG
Yah I hear a wooosh sound when I shift I t'eed in to the CRV and they are connected to the UIM like always.
Old Sep 15, 2002 | 02:05 PM
7-sins's Avatar
thats not paint....
You only hear the wooshing when you let off the throttle? If you are hearing something similar to that (maybe not as distinct) when accelerating then it is leaking. If the door was closed then you should get some off the primary unless something isnt right with the wastegate. You wired open the Turbo Pre-Control... the longer of the 2 actuators right?
Old Sep 15, 2002 | 02:11 PM
7-sins's Avatar
thats not paint....
Also what are your mods?
Old Sep 15, 2002 | 02:20 PM
ejmack1's Avatar
Lawn Ornament
Everything is wired correct;y... there is no boost leak, the ABV and CRV are hoooke up properly... Could a bad Wastgate actuator cause this?
Old Sep 15, 2002 | 02:31 PM
7-sins's Avatar
thats not paint....
What ECU does he have?
There has to be more than one thing wrong... even if the wastegate wasnt opening he would see boost later like 5-6k. Did you pull off and plug all the hoses on the Charge Control Actuator? (the little one on the Y-pipe)
Old Sep 15, 2002 | 02:46 PM
P'cola FD's Avatar
Hamado things my way!
I bet you have a boost leak. There is a description of how to find one here. Try it out https://www.rx7club.com/forum/showth...threadid=98645
Old Sep 15, 2002 | 02:56 PM
7-sins's Avatar
thats not paint....
I remember I had a boost leak but didn't know where it was comming from... I looked at all the couplings and nothing in sight. After scratching my head for a little I actually pulled off the couplings to inspect in my hand and only then could I see the 2" gash in one. Just saying sometimes it takes some work to find one insted of just looking.
Old Sep 15, 2002 | 06:07 PM
adamrx7's Avatar
OG
My mods are not many, I have a HKS downpipe and K&N's. I found a small leak and now get 2 psi.
Old Sep 15, 2002 | 06:25 PM
ejmack1's Avatar
Lawn Ornament
btw he has new couplers
Old Sep 15, 2002 | 06:45 PM
7-sins's Avatar
thats not paint....
I dont know how the Stock ECU will handle after the non-seq.... I haven't seen anyone running that setup, not saying it cant be done. I dont know what tips I can give you.
Old Sep 17, 2002 | 09:05 PM
adamrx7's Avatar
OG
UPDATE I have BOOST
I found a big 3'crack in my lower IC pipe and duck taped that *****. And my pre-contor wire fell off. After i fixed thoes things I was getting like 7psi so I threw on a BMC and it worked great.
Thanks guys for all your help.
Old Sep 17, 2002 | 10:46 PM
spooledUP7's Avatar
Riki Called it!
Old Sep 18, 2002 | 07:43 PM
adamrx7's Avatar
OG
he sure did, After all of that work my car was running good but not great (fell on it's face at 8psi on top end) so I replaced the pulgs and wires (wires were original and plugs had 40k on them) now I have much more low end tork and I gained 2 psi PLUS it pull to redline. I'm so happy.
I'm going for a cruise.
BTW- I have a oil leak at my front engine cover to tackel next
