S5 Interior swap into S4?
Hey has anyone done an S5 into S4 interior swap. I'm not interested in swaping everything, just the gauges mainly and maybe the shift mechanism? I'm planning to put an S5 engine/ecu into the S4 as well so that part shouldn't be an issue. If no one else has done it, I'll give it a shot and post the results when i get to that point...
gauges and shifter swaps have been done and are pretty easy.
If you use the search function and limit it too the 2nd gen section you should see a few posts on each swap.
