Which Wire?
Old Sep 12, 2002 | 08:51 PM
Avatar's Avatar
Which Wire?
Which wire is for what (FC3 Jap import)
Old Sep 12, 2002 | 09:18 PM
Icemark's Avatar
Posted quite a few times, you may wish to use the search function found up in the right hand corner, next time...
here's the radio wires again...
LTBlue/Red= 12v+
LtBlue/White= +Accessory
LtBlue/Yellow= - power ant trigger (not positive like all aftermarket radios- you must use a relay to invert the signal)
Red/Black= + Lumination
White=Factory Amp Turn on
Ground to the body, use the 10mm bolt behind the center console front drivers access panel. Do not use the Red/Black as ground it will damage the interior light circuit and dimmer in the car
Front Speakers (maximum of a 15 watt peak from the radio):
LtGreen/Red= Left
LtGreen/Black= Left
LtGreen= Right
LtGreen/Yellow=Right
Rear Speakers (if applicable, if you have the amplified rear speakers again the Maximum of 15 watts peak is all the stock speaker amp input can handle):
Brown= Left rear
Brown/White= Left Rear
LtBlue= Right Rear
LtBlue/Orange=Right Rear
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
