Where to install temp guage sensor with no drilling?
Old Sep 11, 2002 | 01:17 PM
Black se7en's Avatar
Is there a place to install a temp sensor with out drilling? Somewhere that will give reliable and accurate readings.
Old Sep 11, 2002 | 01:19 PM
grampa's Avatar
My guess is that if there were we'd all be using it
Drilling and tapping the thermostat housing is no big deal.
Old Sep 11, 2002 | 01:35 PM
darkside7's Avatar
yes, you can remove the bolt from the pass side of the filler neck. you have to get an adeptor but it will work
Old Sep 11, 2002 | 01:49 PM
jspecracer7's Avatar
1JZ powered
You could install a water temp adapter inside the upper radiator hose. That's what I did...works like a charm!
Old Sep 11, 2002 | 02:04 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Pics?
Old Sep 11, 2002 | 02:33 PM
1JZ powered
Originally posted by jdhuegel1
Pics?
pics? It's just a piece of metal pipe that that has a hole in it that you screw the sensor into. You cut the radiator hose and put the pipe inside of the hose, and then just hose clamp it down....works like a charm
Old Sep 11, 2002 | 02:41 PM
7-sins's Avatar
thats not paint....
That is a good idea, I might have to use that one day. For now I have it in the water hose going to the throttle body.
If you don't want to drill into your thermostat housing to install the temperature probe, you can install the probe into the throttle body coolant lines by splicing in a 1/8th inch NPT "T". Any hardware store that carries plumbing supplies will have the NPT "T" (Home Depot & Lowe's too). Just take your probe or gauge into the store and find the "T" that fits. You'll need to ground the "T" so the electric probe will work. A mechanical probe doesn't need to be grounded. The AutoMeter mechanical temp probe is so big you would need a much bigger "T". Remember to use Teflon tape or pipe thread compound to seal the threads on NPT fittings, but make sure at least some of the temperature probe's threads contact bare metal for proper electrical grounding.
Old Sep 11, 2002 | 02:50 PM
blackscorpio's Avatar
#1 F0RUM TROLL
I put a metal T (less than 10 bucks from home depot)into the coolant hose behing the UIM. It works like a charm. I will post pics when i get home if you like.
Old Sep 11, 2002 | 03:52 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Is it as accurate as it is in the filler neck? Thanks.
Old Sep 11, 2002 | 05:46 PM
BrianK's Avatar
the only problem with any of these alternatives (including the filler neck) is that you don't get a reading until the thermostat cracks and your coolant starts moving around... so if you have a bad thermostat that never opens, you'll never get a proper reading. I tapped my sensor into the water pump housing so that it's always looking at what's happening in the engine at all times.
$.02
Old Sep 11, 2002 | 06:15 PM
maxpesce's Avatar
Ex fd *****
The hoses to/from the Throttle Body also have hot water circulating through it regardless of the thermostat position. I am planning on using this location (and bypassing the TB at the same time) for my Temp Guage install - this also alows the use of a mech. guage w/ a 6' probe that reads to 280deg insted of the 12' probe model that only reads to 240 deg.
Old Sep 11, 2002 | 10:11 PM
#1 F0RUM TROLL
here is a pic of my temp guage setup.
Old Sep 11, 2002 | 10:19 PM
#1 F0RUM TROLL
Old Sep 11, 2002 | 11:03 PM
paw140's Avatar
After reading this, something just occured to me... I installed my temp sender in the filler neck by drilling / tapping a hole. One thing I really didn't like was how the gauge wouldn't read anything till the t-stat opened.
Later, I had some cooling system problems, and had symptoms similar to a blown water seal (my coolant bottle was filling up, and my add coolant light was coming on). So I put some bars leak (radiator stop leak) in the coolant and the problem went away. Shortly after that, or maybe right after that, my water temp gauge showed the coolant temp as the coolant heated up, before the t-stat opened. Its done that ever since. I've always just assumed that maybe I had been running it on low coolant, or it was just some freak thing. Now, I think the bars leak may have messed up my t-stat, and its open all the time. Any thoughts?
Old Sep 12, 2002 | 01:35 AM
Flyrx7's Avatar
Money Pit
Has it occured to anyone that maybe he was asking about an oil temp gauge, or maybe even an EGT? At least those were my first thoughts as that is whats on my to do list.
Frank
Old Sep 12, 2002 | 10:44 AM
dpasseto's Avatar
Damn....nice setup dude. I've been wondering how to do mine because I bought the 280 degree mechanical autometer gauge which requires a 1/2 in. NPT drill and tap. I'm going to give this idea a try. Thanks. PM me with some tips if you have any.
Old Sep 12, 2002 | 11:11 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
You're the man.
Old Sep 12, 2002 | 11:47 AM
#1 F0RUM TROLL
In the pics one wire is for grounding the sensor and the other goes to the gauge. Its very important to remember to ground it. I forgot to and took me a while to figure it out (had to read the instructions )
Why oh why did it think clear speakerer wire would be good for the fan mod, lol I wish i had used black wire.
Hey for all you out there My MAP sensor is in the lower right hand corner of the pic and it is connected
astrum
24
Nov 15, 2017 08:44 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
