timing for T2
Old Sep 11, 2002 | 12:59 AM
NRA T2's Avatar
timing for T2
how much timing advance is good for a '87 t2 w/91 block and turbo, streetport, 3mm seals, full exaust and intake goodies, 10psi boost max?
Does adding more boost like 12 or thirteen need different timing?
Old Sep 11, 2002 | 02:12 AM
rotarygod's Avatar
Rotors still spinning
If you are running the stock computer I wouldn't change it. Not after the port job. If you do experiment only go a few degrees advance.
The technical answer to your second question is yes, if you are using a standalone efi. For stock computers just leave it alone you can't adjust anything individually just as a whole.
Microtech
30
Apr 23, 2016 06:37 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
incubuseva
14
Sep 3, 2015 12:37 PM
20B Forum
Aug 19, 2015 01:47 PM
