Will 245 work on a 17x7 +38 wheel?
Old Sep 10, 2002 | 12:20 PM
SPDST3R's Avatar
It'll be for the rear for my FC. Just to let u know, I'd like to do this because I wanted to make my rear look wider. Any ideas?
Old Sep 11, 2002 | 05:23 PM
SleepR1's Avatar
No, 245-mm widths require at least an 8-inch wide rim. Do the math--245-mm converts to 9.64 inches:
245 mm x 1 inch/25.4 mm
multiply across, mm dimension cancels, and you're left with 9.6457 inches!
OK, now you try it...
How many inches would a 255-mm width tire be?
Old Sep 11, 2002 | 06:53 PM
SPDST3R's Avatar
Hmmm... you can't just directly do the math on tire fitting. How would you explain a 225mm tire on a 7" wheel?
Old Sep 11, 2002 | 09:07 PM
rynberg's Avatar
To maintain stock wheel+tire diameter, you would need to run a 245/40 17 tire. The minimum width for this size is 8". If you went with a 245/45 17, you would be taller than stock and would still require a 7.5" wheel. Note these are the MINIMUM recommended widths, not ideal.
Ideal width is about 90% of tire width.
Go to www.tirerack.com and look at potential tire purchases. Under the spec section for each tire, it will list the recommended rim widths. You will find that 225/50 is about as wide as you really want to go.
Old Sep 11, 2002 | 10:14 PM
SleepR1's Avatar
Yeah, what rynberg posted
jza80
Aug 12, 2015 11:10 PM
