Side draft on my GSL-SE 6 port.
I wanna do something like that Lake City side draft weber 45dcoe setup , on my gsl-se.
The only thing for 6 ports that im finding (Through mazdatrix) is a downdraft (isnt it?) as it only supplies the upper half of hte manifold to be bolted onto stock...
Atkins sells a setup for $750 w/ a weber carb (a side draft that is), does anyone have any experience with this?
Thanks
Geoff
Thanks
Geoff
Its a side draft upper manifold that bolts to the stock 6 port lower. Uses a DCOE carb. My friend has it on his GSL-SE and I have the same manifold lying around for a 2nd gen.
How does your friend like it?
I am partaking a crusade to humiliate, burn, and generally decimate all hondas, even the S2000's.
I'm going to be pairing this w/ street port 6 port engine, rb exhaust, and a generally perfect tuned engine (ok nowhere close, but i can dream cant i?)
Will this combo be able to do the trick?
A 45 DCOE is probably too small for a stock port let alone a street-port 13B. Get at least a 48 or even the 50mm. Or better yet, get a 48 IDA if you can find one. No other carb has been proven to match the performance, escpecially on ported engines.
Plus, nothing else looks as good in the engine bay.
how about a 58 IDA??
http://geneberg.com/58ida.htm
