thermostat?
Old Sep 9, 2002 | 11:43 AM
ttpowerd's Avatar
HARRRRRRRRR
thermostat?
Which way does it go in? I took it out and then 10 seconds later went to put it back in and I forgot which way it goes? Does the spring side go toward teh engine or toward teh front of the car? I looked in the shop manual but it is not clear and I just want to make sure before filling the system back up.
Thanks
Old Sep 9, 2002 | 03:11 PM
turbojeff's Avatar
Do it right, do it once
Spring goes in the engine. It should only go in one way. If you have a Mazda T-stat make sure to put the "jiggler pin" at the 12 o-clock position.
Jeff
Old Sep 11, 2002 | 11:21 AM
ttpowerd's Avatar
HARRRRRRRRR
what does the "jiggler pin" do and what happens if it not at 12 o'clock?
Old Sep 11, 2002 | 12:27 PM
turbojeff's Avatar
It helps bleed air from behind the thermostat. It will take longer to burp the system if it is in the wrong position or if it is an aftermarket t-stat.
Jeff
MidnightOwl
Sep 25, 2015 10:24 PM
erevos
Sep 15, 2015 09:19 AM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
