Turn Signal/Flasher Control 85 GSL
Old Sep 8, 2002 | 09:39 PM
Bonjo's Avatar
I have an 85 GSL 12A wiring harness I'm trying to salvage. I want to use teh turn signal/flasher control for my custom harness, yet Chiltons and Haynes manual's don't have the same wiring for an 85. The Haynes comes close with it's 13B 85 GSL-SE as it shows the same plugs, but most of the wiring colors are way off.
Can someone tell me what's what. a simple From and To, or a scan of the manual. I will owe you big time.
Thanks
Old Sep 8, 2002 | 10:04 PM
Directfreak's Avatar
I am a Jeeper Now.
The 84's and 85's are the same. 12A and 13B.
Are you trying to put this in another non-Rex or something?
Old Sep 8, 2002 | 10:19 PM
Bonjo's Avatar
Yes. Trying to use as much of my 85 RX as a donor for a Lotus style autocross car.
The colors don't match in the Haynes manual. If I could only tell what wires are coming from, and going to I'd be fine. Without matching colors I can't tell What terminals A-R correspond to without a lot of work/.
Old Sep 8, 2002 | 10:32 PM
I am a Jeeper Now.
Don't waste your time..
Painlesswiring.com
Universal applications
Old Sep 9, 2002 | 06:18 PM
FJ's Avatar
FJ
The harness Directfreak mentioned would be ideal, but to answer your question I've attached a scan of the '84 factory diagram of the CPU. The next post is the pinout of the connector with wire codes.
Old Sep 9, 2002 | 06:22 PM
FJ's Avatar
FJ
The connector and wire codes:
Old Sep 9, 2002 | 09:41 PM
Bonjo's Avatar
Thanks
The photo you posted looks to be right on the money. Now to brush up on wiring schematics.
Thanks, you've been a great help
Bonjo
Old Sep 10, 2002 | 12:09 AM
FJ's Avatar
FJ
Yes, if you do not use schematics very often they can be a bit much. But if all you want is the flasher function, you only need to be concerned with three pins :
-Switched 12V at Q. (The cpu diagram shows pin Q coming from the seat belt warning light, but it is an error. They are missing a dot at the proper junction. The IG key line goes to pin Q and the seat belt bulb.)
-Ground at J
-Pin R goes to the turn signal switch center contact.
-John.
Old Sep 10, 2002 | 09:26 AM
85RX7GS's Avatar
Thanks FJ
Old Sep 15, 2002 | 10:57 PM
Bonjo's Avatar
Thanks FJ
You're right on.
I was hoping I could use more than turn singal and door buzzer.
Thanks Again. I was about to chuck this darn thing.
cristoDathird
28
May 30, 2019 08:47 PM
Rotospectre
Mar 28, 2018 03:33 PM
The1Sun
Mar 18, 2018 11:08 PM
