Adding Light to Disney Fan Mod?
Old Sep 8, 2002 | 07:28 PM
apneablue's Avatar
Question Adding Light to Disney Fan Mod?
Ok guys, I need your expert electricity help with this one...I did the Dave Disney fan mod and it works freaking great...BUT since then I have left the switch on killed my battery twice...
What I want to do is add a red light somewhere that comes one when I turn the switch the fans on and goes off when I turn the fans off...
I was trying to find a source that is on all the time and run the light to that and then splice either the positive or negative light wire to one of the terminals on the switch...However I wasn't successful in finding this always on power source...the flashlight only comes on when you turn the lights on so that didn't help much..
Are there any of you who did this or have a clue how I could go about doing it?
Thanks,
David
Old Sep 8, 2002 | 07:29 PM
apneablue's Avatar
not flashlight...I meant to say ash tray light
Old Sep 8, 2002 | 07:31 PM
saxyman990's Avatar
Place your ad here...
What about splicing into the actual cigarette lighter? I tried using that when hooking up my boost gauge, but I had to switch the wires over to the ashtray, cause I realized the lighter power was on all the time.
That seems like a pretty good idea, and should work well. Where are you planning on putting the light?
Old Sep 8, 2002 | 07:43 PM
Munchy2000's Avatar
Yes, that's my crotch...
why not put an LED right above the switch which goes on when you click the switch up and closes when you click the switch down?
Old Sep 8, 2002 | 08:42 PM
duboisr's Avatar
Is the cigarette lighter hot wire on all the time ? It is not on the 94
Old Sep 8, 2002 | 08:52 PM
Mahjik's Avatar
Mr. Links
Why not just get a lighted switch? You can get them at Radio Shack. I have one, works well...
Old Sep 8, 2002 | 09:02 PM
Rotarius Maximus's Avatar
I was just about to suggest this. Definitely go out to Radioshack and invest in one of the self-illuminating switches.
-Rot
Old Sep 8, 2002 | 09:05 PM
saxyman990's Avatar
the lighter is on whenever the key is in the "on" position. Now that I think about it, this probably wouldn't work for your situation, because you probably want the light to be on even if the key is removed. Oh well, I thought it was a good idea at the time.
Old Sep 9, 2002 | 07:21 AM
apneablue's Avatar
HEy Guys,
thanks for the replies...I did try a lighted switch but for some reason (can't remember exactly) the way it was hooked it never worked and I tried it every other way...I think it came on when the fan was off but when I switched the contacts the light never came on...
right now I mounted a toggle swithc right by the crotch AC vent...it's pretty much hidden and out of the way...I was planning on puttingthe light in one of the blank switched like the defroster is in.
I have a 94 too so I guess the cig lighter is not going to be on all the time either. Damn
Old Sep 9, 2002 | 09:00 AM
blackscorpio's Avatar
#1 F0RUM TROLL
just get into the habbit of turning off the swithches its like getting into the habbit of turning off your headlights at night.
Old Sep 17, 2002 | 11:36 PM
Black se7en's Avatar
Ever figure this one out?
I'm having the same problem...
Old Sep 18, 2002 | 09:55 AM
apneablue's Avatar
Nope...still haven't got it..
Old May 27, 2003 | 09:10 PM
dubcaps's Avatar
that's JDM tyte yo!
I just wanted to rig up some LEDs near the switches so that they would be easier to find at night. I wanted to use the little ashtray light but didnt know what kind of resistors to get, can anyone help me out on this?
-stephen
these are the LEDs that i got from radio shack
http://www.radioshack.com/product.as...Fid=276%2D1622
Old May 27, 2003 | 10:14 PM
one of radio deck wire suppose to have the power all the time.that wire for the memory power for the radio.
I can't remember the color though.
Old May 27, 2003 | 10:19 PM
apneablue's Avatar
Wow, thread back from the dead I never did figure this out...as far as the LEDs I am sure you can just head on over to radioshack and pick one up...but don't you know where you put your switches, why do you need an LED...does anyone smell rice?
Old May 28, 2003 | 08:34 AM
skotx's Avatar
Registered Abuser
I did the Disney fan mod and low/med fan speeds weren't cutting it for me with a FMIC (in my testing, the diff in speed from low to med was almost imperceptible). I played around a little bit, and on my car, I was able to find a single wire that, when grounded, caused the fans to come on high (the speed that only comes on with the A/C). An added benefit is that the fans go OFF when the ignition is off. I also had killed my battery several times with the Disney setup. I'll have to look when I get home tonight to see what relay/wire I'm grounding.
Note: I haven't thoroughly tested this, so I don't even really know what will happen if the switch is on and I click on the A/C.
FWIW, I have a 94 with the fan recall.
-Scott
Old May 28, 2003 | 12:17 PM
laujesse's Avatar
Thrashing your Roy score!
Veteran: Air Force
Use ignition power to the switch???
Old May 28, 2003 | 12:26 PM
spurvo's Avatar
don't race, don't need to
I must have the loudest fans in the world. I can hear them walking away from the car next to a freeway.
Plus I SOOOOOO **** about the things, I pretty much always know when the fans are on. Need to get my head checked!!!
Old May 28, 2003 | 12:55 PM
TwinTurbo93's Avatar
0-rotor-0-turbo-0-fd
Here is the way to connect a LED light to work at the same time when the fans are in on positon and to turn off when fan is off.
Run a single wire to the same relay you did run the wire to ground the relay to switch (ground) the fans on.
On of the thick wires on that same realy is the wire that gives power to fans to turn on, (easy to find out which one with 12 volt tester when you turn the fans on manually with switch, the tester light will turn on and of with fans at the same time) that is where you connect that single wire to the LED light and to ground. Put the LED light on you favorite place in your dash or center console and enjoy your fan light ... real simple.
Old May 28, 2003 | 04:34 PM
Crackers's Avatar
Just to add some information you could allways splice into the turbo timer to shut the fans off when it shuts off. it should be to hard to do it that way. Im considering doing it my self maybe O well just a thought. If you do that It will prevent you from killing your batery.
Old May 28, 2003 | 05:20 PM
JSpecRZ's Avatar
NA2 Pilot
that's exactly what i was goin to say... buy a used turbo timer from ebay... no frills... whatever and just hide it somewhere.. or be slick and make a panel w/ the timer that says "FANS"....
Also, some alarms have a turbo timer function, you can tap into that...
Old May 28, 2003 | 09:25 PM
oakridgerx7's Avatar
i just hooked my fans up to a relay to come on when the ignition switch is on and it shuts off when the ig. switch is off. my temps never get over 195 degrees.
Old May 29, 2003 | 01:28 AM
Flyrx7's Avatar
Money Pit
Why is it people are going through the trouble of hooking up the fan mod this way to get 2 speeds (or whatever) instead of just hooking them up with the wire behind the ECU? When hooked up with the wire behind the ECU the fans will turn off in 10 minutes, plus, if after 10 seconds from when the ignition is turned off and the switch is thrown, the fans will run on medium instead of high. Is there some kind of benefit to this type of hookup?
Frank
streetlegal?
Mar 17, 2022 02:46 PM
torky007
Aug 17, 2015 05:14 PM
