Odd Brake noise when reversing..
Old Sep 8, 2002 | 01:23 PM
TheAMAZINGNorad's Avatar
Question Odd Brake noise when reversing..
Hi guys. Something odd started happening the other day. I was rolling down my friends driveway and had to stop because some jerk was flyin down the road at like 50mph. Well, when i steped on the brake a click/pop sound came from the drivers side of the engien bay. Pretty close too. I was like.. wha? So i tried it again..same thing. When you first depress the brake pedeal it makes this pop click sound..but ONLY when Iam rolling backwards. So, if I am rolling backwards, everytime i depress the pedal it goes pop. It dosent do it when i am going forward. Now since the master cylinder is driver side of engine bay and close (thats the master right?) i was wondering if maybee it was going bad? I checked my brake fluid level and it was ok. Why is it only doing it in reverse?
Old Sep 8, 2002 | 01:34 PM
Manntis's Avatar
add to cart
maybe it's something else shifting when your car goes into reverse and banging against the firewall.
Old Sep 8, 2002 | 01:39 PM
diabolical1's Avatar
check to make sure the bolts that secure the caliper assembly are both there. my car did a similar thing a few years ago, and it turned out that one of the bolts was missing.
Old Sep 8, 2002 | 05:20 PM
inittab's Avatar
I read your email
Check your drivers side tension rod.
The1Sun
Sep 15, 2015 04:45 PM
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
83revival
Sep 3, 2015 10:42 PM
