Motivation is gone :(
Old Sep 6, 2002 | 05:49 PM
ejmack1's Avatar
Lawn Ornament
Well my car has been on jackstands for nearly 2 months now, I have the 5 spd tranny in, drive shaft in, and PPF in. All clutch lines ran, starter bolted on. Pedals hung. Well the only problems im running across is, the pedal does not seem to have engagement point, Im having a little trouble adjusting it, and the wiring is confusing me. I have heard of people converting the stock harness over but after reading the manual night after night, I still do not see how this is possible. I guess my questions are
1. Anyone have some suggestions for adjusting the clutch.
2. Anyone have any information on the wiring.
Thanks
Eric MacKenzie
Old Sep 6, 2002 | 06:03 PM
SPOautos's Avatar
Hey, where did my $$$ go?
Re: Motivation is gone :(
Thanks
Eric MacKenzie
Have you bled the slave yet??? That can make a big difference
STEPHEN
Old Sep 8, 2002 | 11:46 PM
Flyrx7's Avatar
Money Pit
Thanks
Eric MacKenzie
Are you sure that the throwout bearing is engaged into the pressure plate? There is a ring on the PP that the throwout bearing snaps into, check that.
Frank
Old Sep 8, 2002 | 11:51 PM
7-sins's Avatar
thats not paint....
I give you props if you’re trying to get an auto to a 5 speed. I was looking into the idea when looking at cars and ruled out because it seemed pretty in-depth. Sorry I don’t have any advice just moral support.
Old Sep 9, 2002 | 12:36 AM
SUPRAMAN
i had it done to my second gen. Good luck bro props to anyone who has the ***** to try it.
Old Sep 9, 2002 | 01:21 AM
machinehead's Avatar
kortez
I have done it. I think you need to bleed the slave. Sometimes its not easy if the master is dry, which it probably is. What you need to do is open the bleeder, have someone push the pedal down, then close it. Lift the pedal back up and do it again until you get a decent amount of fluid coming out. Once that happens you can start pumping and bleeding like you normally would. If the master is dry and you try pumping right away you just suck the air back up the line.
The wiring is a bit of a pain. I actually got all my **** to work with the automatic harness. Even the shift switches and back up lights. It is a pain but not very complicated, you just cross over between the two diagrams, manual and auto. The only thing I never got to work correctly was the cruise control but I didn't want that anymore anyway so I didn't screw with it too much. Some of the switches on the trans may not even be needed, I put them in there just to be sure.
Old Sep 9, 2002 | 01:51 AM
dclin's Avatar
Perpetual Project
Try George at www.sevenspeed.com . The last time I talked to him, we discussed sending my wire harness to him for him to rewire.
I ended up doing the auto/tranny swap the easy way - wrote out a check to MZM in Austin - www.mzmperformance.com - and let them do it hehe.
Old Sep 9, 2002 | 12:14 PM
JONSKI's Avatar
5yr member, joined 2001
Eric, Eric, he's our man.
If he can't do it, I sure as hell can't.
*cue in loud echo*
You must do it! Do you not feel the pain of your fellow AT FD owners? Are you abondoning your RX-7? IS THERE NO JUSTICE TO BE DEALT? Then get your *** in gear, for it IS your birthright!
Old Sep 9, 2002 | 11:06 PM
ejmack1's Avatar
Lawn Ornament
lol, well, i got her to crank over, but its not taking, i'm getting spark and fuel. I think i have a few bad ground, gonna be workin on it tomorrow, Im not worried about the wiring any longer. If anyone can find new stock connectors i would be really interested. I would like to make a how to specifacally on the wiring, but it would be a lot nicer with stock connectors. I used some connectors out of an old 626 and just spliced the wires....
Jonski - Give up? Thats out of the question, this is my daily driver and my transportation to school, lol!!! It will be done. And a comprehensive how too will be done, I think the cost I have in this will make some of you guys sick!!!! with envy that is Its well under 1K...
Old Sep 9, 2002 | 11:08 PM
ejmack1's Avatar
Lawn Ornament
updated picture of poor car... it is at least back on the ground!!!!
Old Sep 9, 2002 | 11:09 PM
ejmack1's Avatar
Lawn Ornament
and dont make fun of my vielside front or dirty carpet!!!!! The car is in enough pain!
Old Sep 9, 2002 | 11:30 PM
spooledUP7's Avatar
There and back again
If you have not figured the pedal feel, Flyrx7 said it right. The FDs clutch is a pull style and needs the release bearing to snap into the pressure plate ring. also, make sure the clutch piston lines up with the clutch arm.
Old Sep 9, 2002 | 11:44 PM
ejmack1's Avatar
Lawn Ornament
im getting movement on the Throwout bearing and ring, the pedal feel is there, just really really light, not like a regular clutch...
Old Sep 10, 2002 | 12:57 AM
7sweetie's Avatar
Pilots are hot!
veilside.....isnt.....that.....bad........really im sorry, i feel for your car......poor thing
Old Sep 10, 2002 | 01:11 AM
ejmack1's Avatar
Lawn Ornament
im gonna cry
Old Sep 10, 2002 | 07:24 AM
JONSKI's Avatar
Dude, if you bought my wing, you'd have half the kit!
Old Sep 10, 2002 | 08:11 AM
ejmack1's Avatar
Lawn Ornament
shut up man!
cooldude
West RX-7 Forum
Oct 3, 2015 09:17 PM
meat_whistle
Aug 12, 2015 08:41 PM
Myc1972
Jul 28, 2005 09:44 PM
