Factory Alarm Probs
Old Sep 4, 2002 | 06:57 PM
bhodge's Avatar
Question Factory Alarm Probs
I did a search on factory alarms and really couldn't find the answer to my question. My alarm arms when you lock the door just fine. The problem is that the damn thing will not turn off. I have tried the lock/unlock trick in the drivers door and it still keeps going. Any suggestions? Is there any easy way to disable it?
Old Sep 4, 2002 | 07:04 PM
kundo's Avatar
try the passenger door, works for me.
Old Sep 4, 2002 | 10:33 PM
spooledUP7's Avatar
There and back again
If you are talking about the stock alarm system failing on its own without an aftermarket alarm, then here's what you do.
Pull the plastic panel off the back side of the drivers, and passenger door handles. Un bolt the door handle assembly.
There is a small white switch that when new snaps over the tumbler drum. You will need to snap them back on making sure to align the tumbler notch. Use a zip tie to keep it on or a dab of hot glue.
I hope this helps.
Turblown
Sep 30, 2015 05:58 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
