help, car wont accel past 3k
Old Sep 3, 2002 | 01:38 PM
prew's Avatar
Question help, car wont accel past 3k
my car sat for a week when i was at school. when i got home the car would rev fine. then i took the car down the road. let it warm up a minute. when i got on it and tried to accelerate in a gear past about 3000 rpm it bogged completely, almost like its ussual split second stutter. i drove the car slow for awhile, the temp was fine, why is it doing this? thanks. -Steve Prew
Old Sep 3, 2002 | 01:39 PM
prew's Avatar
oh btw, my only mods are catback and dp. also silicon boost lines.
Old Sep 3, 2002 | 01:41 PM
SPOautos's Avatar
Hey, where did my $$$ go?
If you have a lot of miles you prob have a cloged cat or it might be in limp home mode. I think if you disconnect your battery and hit the brake or something it will reset the ecu and get out of that mode. You might want to try that first and if it doesnt help pull the cat and drive down the road to see if it helps.
STEPHEN
Old Sep 3, 2002 | 01:42 PM
JUSTgotMINE's Avatar
Mine is in the middle of this problem too. I did the self diagnostic test with the paperclip and got error code 45....you may also want to search under "limp mode".
Old Sep 3, 2002 | 01:43 PM
prew's Avatar
hmm, well my dad left the door open, so the battery was dead when i got home also. the car has 70k miles.
Old Sep 3, 2002 | 01:44 PM
beyondlimitz's Avatar
check your vac lines, there may be something that came loose or disconnected.
Old Sep 3, 2002 | 01:46 PM
prew's Avatar
that sounds like it may be, recently my car has been making a blow off valve noise, but i dont have one. i couldnt figure out where it was coming from.
Old Sep 3, 2002 | 01:58 PM
Mahjik's Avatar
Mr. Links
Actually, you do have a blow off valve...
Do you have a boost gauge installed? If not, now would be a good time to get one.
Old Sep 3, 2002 | 08:58 PM
MazdaMike's Avatar
lol check ur gas, u runnin on fumes, hehe u better not be. yea i wouldnt be suprised if one or 2 vac lines may have disconnected, doesnt sound like a major problem
-mike
Old Sep 3, 2002 | 10:07 PM
prew's Avatar
yea, i gotta check it out. the car has a half tank of ultra 94 from sunoco in it, thats the only way i roll.
Old Sep 3, 2002 | 10:40 PM
t-rex7's Avatar
If you see smoke coming from the exhaust it could be your boost control. Try to see if the line came off of that. (the boost control is on the firewall)
Old Sep 4, 2002 | 12:05 AM
GsrSol's Avatar
Z06 powered FD
If your battery went completly, wouldn't the ecu still be in a "learning" mode?
Old Sep 4, 2002 | 10:11 AM
paw140's Avatar
GsrSol: I've never had a problem like that from disconnecting the battery.
My car is doing the same thing, and its going into Limp mode because my oil metering pump is malfunctioning. Bad wiring or something. Does your check engine light come on? Pull the codes, I bet you'll find something.
Old Sep 4, 2002 | 10:43 AM
blackscorpio's Avatar
#1 F0RUM TROLL
I have to chip in in here. Could be the MAP senso hose that poppes off. When this happens you get bogging at WOT some smoke and a gasoline smell. Also the car would have an eratic Idle. If you have these symptoms do a search on MAP sensor and youll find lots of info.
Old Sep 4, 2002 | 09:24 PM
prew's Avatar
hey guys, my dad just called me from home. as i said before the battery was completely dead when i came home and it was runnin shitty. turns out it was just an electrical problem, because my dad went to mazda today and bought a new battery, put it in, and shes boostin fine. thanks for all the suggestions of what it could have been. shes rippin now. -Steve Prew
fastrx7man
33
Sep 2, 2015 09:42 PM
gtcd
30
Aug 19, 2015 02:44 AM
cam_7779
Aug 18, 2015 07:48 AM
