aftermarket power antenna
Old Sep 3, 2002 | 12:24 PM
bmphone's Avatar
does anyone make an aftermarket power antenna
Old Sep 3, 2002 | 12:48 PM
Icemark's Avatar
Quite a few companies make aftermarket power antennas. Harada, Hirshman, Autowerks, etc.
The factory antenna is made by Harada... and in most cases can be repaired or replaced
Old Sep 3, 2002 | 12:55 PM
kllntyme's Avatar
Legend in my Spare Time
Circuit City sells several that should work. They can even install them for a slightly higher fee.
Old Sep 3, 2002 | 01:12 PM
cluosborne's Avatar
I replaced mine with a Radio Shack power antenna, about $45-50. It fits very well, using the factory braket (simply needing to be flipped, using one less screw). If you're using the factory stereo, you'll have to install a bypass switch or simply find a switched 12V lead (which will raise and lower the antenna with the ignition is on/off).
Reception is good, and I've had no problems.
Old Sep 3, 2002 | 01:55 PM
DaleClark's Avatar
RX-7 Bad Ass
You can get a new factory antenna mast for like $20-30, take apart the antenna motor and dig all the guts out, then feed in the new one. It's a REALLY easy job.
I think Mazdatrix has some info on it on their site.
Dale
Old Sep 3, 2002 | 02:06 PM
vaughnc's Avatar
knowledge junkie
btw - if your stock antenna motor works - but the antenna doesn't raise and/or lower - you can just replace the antenna core itself for $25. Your local mazda has the antenna core.
Old Sep 3, 2002 | 02:07 PM
DaleClark's Avatar
RX-7 Bad Ass
The motors rarely go bad - they're pretty hardy. The antenna replaces everything that goes up and down - the metal mast, the nylon cord inside, etc.
Dale
Old Sep 3, 2002 | 03:14 PM
bmphone's Avatar
thanks for the info
streetlegal?
Mar 17, 2022 02:46 PM
LunchboxCritter
15
Jan 3, 2016 04:11 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
