How do I stop sqeaky belts?
Old Sep 3, 2002 | 02:26 AM
kevino's Avatar
I'm just wondering if anyone knows a good way to stop sqeaky belts. I put belt dressing on pretty regularly but it's no permenant fix. I've considered maybe sanding them smooth and repainting them, but I think the paint might wear off pretty quick. thanks for any suggestions.
-kev
Old Sep 3, 2002 | 07:24 AM
black7's Avatar
A bar of soap to the belt with engine running worked well for me until I was able to pick up some new belts.
Old Sep 3, 2002 | 07:26 AM
Rxmfn7's Avatar
Do a barrel roll!
Get bew belts. Belt dressing is a temporary fix but doing it over and over will make the belt soft and more prone to snap. Just spend a few $$ and get new belts.
Old Sep 3, 2002 | 10:34 AM
HAILERS's Avatar
HAILERS
Just in case.........if your running without the airpump, expect the water pump belt to slip. If you have the airpump installed, disregard this post.
Old Sep 3, 2002 | 12:02 PM
Roy James's Avatar
My cars louder than yours
Yeah, if your belts are pretty good looking, i would get a duel alt pulley and run two belts on that. That way you have twice the belt power. Again, if you have your air pump, like Hailers said, disreguard this post. heh
Old Sep 3, 2002 | 01:30 PM
A quick fix, if the belts don't actually need replacing, is to have the car running and pour a very small amount of oil ( 1/2 cap) on the belt as it's spinning. This works and is an old mechanics trick.
Old Sep 3, 2002 | 02:02 PM
vaughnc's Avatar
knowledge junkie
stick with stock belts as well. I seems the aftermarket ones like to squeek in the winter.
Old Sep 3, 2002 | 09:36 PM
dre_2ooo's Avatar
Umm.... sqeaking belts usally indicates them being LOOSE.
