engine porting questions
Old Sep 2, 2002 | 09:51 PM
I've got a few questions about street porting my 87' N/A:
#1- If I street port my engine, will I still be able to pass emissions? It would seem that I would be able to, hence "street" port, but just making sure.
#2- Do I need to buy templates to do the porting, or can I make my own templates?
#3- How difficult is this task? If it's doable, I'm up for the challenge. Doesn't look too hard from the write-ups and how-to's and what not, but I've never done it before.
#4- Is there anything else I should know before attempting this?
Thats all I can think of, for now. Thanks in advance
Old Sep 2, 2002 | 10:03 PM
Evilinside944's Avatar
I would also like to know if you need any special tools or can this be done with a dremme and some grinding bits?
Old Sep 2, 2002 | 10:17 PM
does anyone know anything about this?
Old Sep 2, 2002 | 11:37 PM
88 SE's Avatar
I was thinking about doing this but after soem thought and thoughts from other forum members I came to a conclusion.
Its not worth it.
Seems like with 13b 6-port engines a street port isnt gonna give a whole lot of gain, especially not for the $250 it costs. (even if you do it yourself, dremel is $50 and templates are another $80)
Based on this I decided not to do it on my engine.
Old Sep 3, 2002 | 12:05 AM
black_sunshine's Avatar
#1 -- You MIGHT pass. Depends on a LOT of variables (how soon you open/close the exhaust/intake port(s) and the type of exhaust system)
#2 -- Templates? If you don't know what you're doing, GET THEM. Make sure to match them to the pictures on mazdatrix's website (www.mazdatrix.com). BTW, don't expect to pass smog. The templates open the exhaust earlier into the combustion cycle, this more unburned fuel escapes.
#3 -- Doable? Sure is. It's not hard to do, but it is very time consuming. If you have patience, I suggest you use it. Also, make sure your grinding skills are up to the challenge by cutting on junk metal or something (an old lawnmower motor block works great!)
#4 -- Any hidden things? Buy the correct tools! Don't skimp-out on good quality bits/stones. Get 3 different types of "firecrackers" (sandpaper dowels); medium, fine, and extra fine. Make everything nice, smooth and straight. Bevel the edges where you cut, so the seals don't potentially catch the lip of the port and do damage.
Old Sep 3, 2002 | 01:13 AM
88 SE's Avatar
Oh yea, dont forget since its an N/A you cant port the exhaust
Not unless you have a way to grind that diffuser out
Old Sep 3, 2002 | 12:26 PM
RacerXtreme7's Avatar
NASA geek
Porting 101
Go get your learn on... http://mazdatrix.com/faq/porting.htm
Old Sep 3, 2002 | 04:12 PM
Jimmy325i's Avatar
No longer cares
I used an abrasive blade on my sawzall to cut the tops of the difusers off and then used a carbide cutting bit to take the stubs down.
The inserts are SS so they're really hard, but it can be done in less than a couple hours.
If you're porting the exhaust on an N/A motor you wouldn't want to lower the exhaust port (causing it to open earlier) because that will kill your torque. I raised mine maybe 1/4" and smoothed it into the insert so that it increases the overlap slightly (benefitting higher rpm power) so as to increase the exhaust scavenging and suction on the intake charge which results.
And this is my first rotary rebuild... Who needs templates? Look at the pictures and look at the housings. You just need to make sure they all match each other.
Old Sep 3, 2002 | 05:38 PM
crap. I can't risk not passing smog. I guess I'll forget about porting my engine, or maybe just a little tiny bit hehe. maybe I'll add a custom turbo kit someday, or do a jspec swap thakns for the help
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
