why does my clutch stick to the floor?
Old Sep 2, 2002 | 04:50 PM
Ridge Tech's Avatar
I've tried adjusting it with no avail it i go one way the clutch doesn't release enough, it i go the other way it make the master cyclinder move when you press the clutch. I've found the happy medum and now the petal will get stuck in the down positon when i bring my foot up. I keep stalling, any ideas?
Old Sep 2, 2002 | 05:10 PM
jspecracer7's Avatar
1JZ powered
Re: why does my clutch stick to the floor?
sounds like your clutch maste cylinder needs either a rebuild or a replacement.
Old Sep 2, 2002 | 05:17 PM
Gene's Avatar
10 lb. boost, 5lb. bag
Yup mine did this too. I had to tie my foot to the pedal so I could yank it up to limp home. Time for a new one! They're not expensive and the swap doesnt take long. Be careful when bleeding the clutch slave because it's sorta a pain in the *** the way it's buried. I got a speedbleeder fitting for mine
Old Sep 2, 2002 | 07:08 PM
SonicRaT's Avatar
Super Raterhater
you could just try to bleed any air out of it before you go replacing everything.
Old Sep 2, 2002 | 07:13 PM
TurboSmoke's Avatar
Getting Boosted
bleed the lines and if it still sticks you need a new mast cyl. thats what happeded to me
Old Sep 2, 2002 | 07:25 PM
Ridge Tech's Avatar
with the bonez clutch it would make sense that the master cyl. would die.
Old Sep 2, 2002 | 10:32 PM
master cylinder alright.. i was like that for like 3 months..if u press the pedal in slow.. it'll stick but if u press the pedal really fast it never sticks.. lol its only like 50 bucks for clutch master cylinder.. one of tha cheaper parts of our cars..
Old Sep 2, 2002 | 11:02 PM
Ridge Tech's Avatar
autozone has it for $70, still not bad
iluvrx7z's Avatar
I had the same thing happen to me at college with no real tools or anything to fix it. It ended up being the master cylinder...not too hard to replace.
Dan
Old Sep 3, 2002 | 07:09 AM
SSearch's Avatar
Have you tried lubricating the pivot point for the pedal? This fixed mine.
Old Sep 3, 2002 | 09:49 AM
Ridge Tech's Avatar
taking it apart i found that the push rod that goes from the petal into the master cyl. is bent. What in the world could have caused that to bend, it looks like its made of solid brass?
Old Sep 3, 2002 | 09:58 AM
those hard 1-2 2-3 3-4 shifts cause it to bend lol
who knows ours cars are 11-16 years old.. over 100,000 miles.. things like this stop working and getting older just my 2 cents.. and dont go for the rebuild kit.. for some reason it sucks.... i tried it and lasted a week...
risingsunroof82
Sep 9, 2015 08:06 PM
Frisky Arab
Sep 4, 2015 06:17 PM
