Heat Gauge high sometimes is my car overheating?
Old Aug 31, 2002 | 07:30 PM
RylAssassin's Avatar
Question Heat Gauge high sometimes is my car overheating?
Hey guys, When driving on the highway i notice that my heat gauge fluctuates to certain points very consistantly. At 70mph or under it stays around the half way mark but if I bring it to 80 or higher it imediatly goes higher like to the 75% mark and stays there. Ive never noticed it going higher than 75% even at 100-120 miles per hour but if i cruise at 80 its always at the over half way mark. Is this bad? Is my engine posibly overheating or is this normal for this speed and rpm?
Old Aug 31, 2002 | 08:04 PM
Ni5mo180SX's Avatar
White Comet
Something doesnt seem right here. You have an S4 (normal temp area is supposed to be around 1/4-1/3 of the way up) but you're hitting half way? You reaching 75% on an S4 should mean your engines wayy overheating and you should be seeing the effects very soon. That or it could be maybe your coolant temp sensor is messed up. Not sure.
Old Aug 31, 2002 | 08:07 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
Hate to be a pestamist, but my car started doing that at the end of spring.. about 2 weeks later it got parked and hasnt moved much sence, if i were you i would start saving
-Jacob
Old Aug 31, 2002 | 11:53 PM
jacobcartmill's Avatar
just dont care.
my gauge usually sits at halfway all the tme.
Old Sep 2, 2002 | 05:54 PM
deadRX7Conv's Avatar
Opinions are like........
You could tear through the cooling system and hope that its something simple and not a toasted engine seal.
Start with the thermostat(use Mazda), cap, hoses, coolant-antifreeze flush etc.....
gtcd
30
Aug 19, 2015 02:44 AM
LMBTG
Aug 15, 2015 01:43 PM
befarrer
Aug 14, 2015 04:18 PM
04G35S
Aug 14, 2015 07:31 AM
