My car wonīt shut off. New Engine.
Old Aug 31, 2002 | 06:19 PM
RexTech's Avatar
Hello pals, I just installed a reman. Mazda engine to my 1987 N/A (base model, I donīt know if SE or GLS or what). The engine start pretty good, at once. Some minor adjustments. The problem is that the car wonīt shut off, I took the key out the switch, but the car still on. I didnīt install new electrical equipment or something new. Is my car alive? . The car was 5 months stopped before the new engine.
What should I do?
Thanx for help. RT.
Old Aug 31, 2002 | 06:25 PM
Aaron Cake's Avatar
Engine, Not Motor
Key switch stuck? Relay stuck? If it's been sitting for 5 months, things like that can get sticky.
Old Aug 31, 2002 | 07:44 PM
GatorRX's Avatar
Check which plug you plugged into the back of the alternator. It should be the white plug with the (I think) black/white wire attached. There are a couple of others there that fit in the same socket, if you messed this up, you can get the same situation.
Ignition switch is another good one...
Old Sep 1, 2002 | 01:19 AM
RexTech's Avatar
Thanks guys, Iīm going to check that points tomorrow morning and I will report back.
Old Jan 24, 2003 | 12:19 PM
RexTech's Avatar
Thanx guys, it was the alternator plug inverted.
immanuel__7
89
Sep 5, 2015 10:23 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
