Drilling through firewall
Old Aug 31, 2002 | 11:02 AM
Decay's Avatar
Anyone have good shots of where they drilled through the wall? I am doing the fan mod and I cant get to the effin ECU grommet, its such a PITA. Thanks in advance.
Dan
93 VR r1
Old Aug 31, 2002 | 12:12 PM
Qball's Avatar
Comp Yellow Mica
why dont you poke a small hole in the where the steering column goes through the firewall.
its a rubber surrounding. thats where i passes by boost line through.
dont make it too big.. just enough to pass the wires so you wont get engine stink in the car.
Old Aug 31, 2002 | 02:09 PM
boostedrotor's Avatar
if you look behind the fuse panel, there is a hole that goes into the fender well under the cruise control chingas that's bolted to the driver side fender well......
Old Aug 31, 2002 | 02:35 PM
Fd3BOOST's Avatar
Recovering Milkaholic
Just stick a drill bit through the wall left and below the cruise control.
Old Aug 31, 2002 | 02:38 PM
RonKMiller's Avatar
Blow up or win
Take a coat hanger, straighten it out, sharpen the tip with a file and tape your wire about an inch below the tip with several tight wraps of masking tape holding it flat against the wire.
Poke the sucker through the grommet.
Keep the coat hanger, you'll use it again someday.
Old Aug 31, 2002 | 03:37 PM
MazdaMike's Avatar
hehe so ghetto but soooo effective
Old Aug 31, 2002 | 06:47 PM
Decay's Avatar
Good looking out guys. I'm filing my hanger as I type
P.S.- I gotz an R1, no cr00se
cto_2
19
May 8, 2018 08:15 AM
