Detonation
Old Aug 30, 2002 | 02:47 PM
wallin's Avatar
Detonation
I went and got a price quote for a full exhaust he said it would cost in the $400 range for mandrel bent piping all the flanges and stuff( 3" Turbo2 Downpipe Included). I was wondering though if i get this would I need fuel mods if kept my boost low. I have a manual boost controller that i could set for like 5 pounds or so would i still need a new fuel pump and maybe even Injectors. I am planning on still getting the fuel cut controller and everything if there is something else i should get or if i will need other fuel mods let me know.
Old Aug 30, 2002 | 02:57 PM
eViLRotor's Avatar
Brother of the Rotary
An upgraded pump is pretty cheap.
Better safe than sorry, IMO...
Old Aug 30, 2002 | 03:03 PM
wallin's Avatar
I don't have the money for a fuel pump. If i need one to run i will not get the exhaust.
Old Aug 30, 2002 | 03:12 PM
eViLRotor's Avatar
Well, if you have just intake and exaust, you should still be ok.
Be sure to at least re-wire your TII pump so that it gets constant voltage. There is a write-up on that somewhere.
But even a used FD fuel pump would be better for the future.
Old Aug 30, 2002 | 06:48 PM
adamlewis's Avatar
Back from teh deadly!
If you get 3-inch all the way back, youll still get boost creep/spike...especially with the cold weather getting closer.
Just save a little more money and do it the right way.
EDIT: You do realize that boost controllers are generally used to raise boost....right?
Old Aug 30, 2002 | 08:07 PM
BlackFC's Avatar
Not only is that what they are generally used for, BUT thats all they can do. I bet if you searched for this you'd prolly find your answer about 392482390489023 times......
Daniel
Th0m4s
Feb 26, 2019 02:04 AM
Howard Coleman
The Good Businesses
Sep 15, 2015 10:31 AM
msilvia
15
Sep 11, 2015 12:13 PM
A-Spec
Mar 15, 2002 03:52 AM
