BAC Valve
Old Aug 29, 2002 | 12:52 AM
MAX-IMAL's Avatar
Respect Brotha!
BAC Valve
Hey ya'll, my BAC valve is leaking coolant I think the seal is broken or something can i fix it,or do i need a new one?
Thx
MAX
Old Aug 29, 2002 | 03:47 AM
Liquid Anarchy's Avatar
We come with the Hardcore
I think that's just like... a pipe. It doesn't go anywhere. Do the TB mod (found on fc3s-pro.com) and get rid of that coolant line all together.
Old Aug 29, 2002 | 04:14 AM
Scott 89t2's Avatar
SOLD THE RX-7!
there is no need to run the lines through the BAC valve. you can pull those 2 lines off (it'll spray) and connect them with another small pipe or something, unless it's the hose that is leaking. if so you can just change that.
Old Aug 29, 2002 | 04:29 AM
Sorry to abduct your topic, but I have a quick question.
I'm ditching pretty much everything but the Alt on my car. I'm wondering if I ditch the A/C, can't I get rid of the BAC? Will it be hard to adjust the Idle w/o it? Block-off Plate? THX.
Old Aug 29, 2002 | 01:02 PM
MAX-IMAL's Avatar
Respect Brotha!
Well i checked the hoses and they are ok. no leaking but is leaking where is pluged in to the bac valve i think theres some sort of seal that separates the baca and thecoolant duct.
Although i'm gonna do what scott said.
Thx guys.
MAX
Old Aug 29, 2002 | 01:21 PM
MAX-IMAL's Avatar
Respect Brotha!
I think it would,once tried to adjust the idle w/o the bac, drove the car with the bac disconected and run roughly and a very low idle ieven wasn't getting the 3k when start cold, so just plug it back and everything went back to normal.
Old Aug 29, 2002 | 03:08 PM
Aaron Cake's Avatar
Engine, Not Motor
Leave the BAC valve. Removing it is not worth the trouble it causes.
Old Aug 29, 2002 | 03:45 PM
wpgrexx's Avatar
i have taken mine off, for the first few days it was not being nice, stalling running rough and what not. After countless adjustments, i have gotten the car to idle at 750 rpm once warm, it takes about 5 min of holding the throttle up manually and then it idles fine.
Old Aug 29, 2002 | 04:48 PM
silverrotor's Avatar
[QUOTE]Originally posted by wpgrexx
i have taken mine off, for the first few days it was not being nice, stalling running rough and what not. After countless adjustments, i have gotten the car to idle at 750 rpm once warm, it takes about 5 min of holding the throttle up manually and then it idles fine. [/QUOTE
What was your purpose of removing the BAC Valve?
Old Aug 29, 2002 | 08:59 PM
One less valve, and if you ditch emissions, no more tube between the AFM and the TB.
Old Sep 4, 2002 | 02:51 AM
Jimmy325i's Avatar
No longer cares
The BAC valve is what the computer uses to maintain a smooth idle.... has NOTHING to do with emissions. Where do people come up with this crap??
The BAC valve is capable of much more finite adjustments to the air entering the engine at closed throttle. So, this "bypassed" air is directed around the throttle body into the intake manifold allowing for a smooth idle. Elimination of the BAC valve will force the engine to idle through the throttle body and will idle like **** cold because of it.
Rotafuzz
Sep 30, 2015 09:55 AM
