Vibrations at 1k to 3k
Old Aug 28, 2002 | 06:17 PM
LoSRx7's Avatar
Anyone have this prob or know what it could be???
At idle from 1k to 3k i feel a vibration on the steering wheel and a little on the shifter. I look at the engine and it doesn't shake at all, and u can't feel any vibrations. Only on the steering wheel and a bit on the shifter. Anyone know whats up?? Just started happening 2 days ago, and the car is driving fine that i know of. Hope someone can help.
LoS
Old Aug 28, 2002 | 06:36 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
Mabya wheel out of balance, my wheel shaked alot at low rpm's/speeds when mine was out of balance
-Jacob
Old Aug 28, 2002 | 07:07 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
At Idle, good question.
Driving down the road:
Shaking steering wheel, has to be alignment, tire out of balance or out of round, bent wheel perhaps (but not likely)
Shaking shifter, bad tranny mount most likely. Maybe bad U joint shaking things up.
But shaking only at 1-3 K? I dunno.............
Old Aug 28, 2002 | 07:39 PM
Ryde _Or_Die's Avatar
It doesn't vibrate at all while driving? Hmm, weird. If it starts to you might wanna look into a new driveshaft.
Old Aug 28, 2002 | 10:39 PM
LoSRx7's Avatar
My sub smokes one evening, so i take it out. Next morning i get this stupid vibration. I'm not positive if it shakes while moving, but i'll let u know tomorow. My car prob misses my sub.
Thx guys
LoS
Old Aug 29, 2002 | 06:37 AM
Doah, my bad, i missed the "viberates at idle"
Shake at idle? is it a rough idle?
Question: If your motor mounts were bad would the engine rock or move more even while idling?
Im not expert but thats what came to my head
Old Aug 29, 2002 | 08:39 AM
LoSRx7's Avatar
The engine doesn't shake at all.
At idle u feel a little vibration. Feels like when u spin a ball in a loop. U can sense something spinning around. Something like that. At idle u can barely feel it, but as it goes above 1k towards 3k the feeling gets faster and faster and when it goes over 3k u can't feel it hardly at all.
While driving u can feel it a bit, but its tough to tell because of the bumps on the street and i have a full suspension, so i feel every little thing. But the car pulls fine and goes fine. I just hope its nothing serious, but i can't figure it out I'm having a rough week!!!!
LoS
Old Sep 9, 2002 | 10:28 AM
LoSRx7's Avatar
Can't Anybody help?? Anyone have pics of where the tranny mount is???? Thx
LoS
Old Sep 9, 2002 | 11:01 AM
blu_gxl's Avatar
did you check the tention of all your belts?? it could be a loose or worn belt or tentioner that could explain why you feel it go away at higher rpm. other than that BIG MAYBE leading coil it's probably not but doesn't hurt to check
Old Sep 9, 2002 | 11:12 AM
Josepi's Avatar
Despise Enmity
Just curious, is the vibration load dependant? IE WOT shakes more than decel?
Old Sep 9, 2002 | 11:38 AM
LoSRx7's Avatar
After 3k/ 3.5k you don't feel **** Maybe it is my belts. I'm going to check it out.
LoS
Old Sep 9, 2002 | 01:16 PM
Rotorific's Avatar
I dont know a damn thing
IF your rolling then its out of balance and you need a front end alignment a key way to see is if your wheel shakes which it does so go get a 40 buck alignment not a $130 because rx7s rarely go out of alignment so its not really worth 130 unless you feel it is peace
Old Sep 9, 2002 | 02:39 PM
LoSRx7's Avatar
PHEW FOUND OUT THE PROB
the alternator wasn't bolted on 100%
i forgot the nut on the back bolt. All set.
LoS
DaleJK
Aug 31, 2015 10:19 AM
MasteRX
11
Dec 3, 2001 01:43 AM
