Does a 88 GXL have 4piston calipers and a aluminum hood?
Old Aug 28, 2002 | 10:22 AM
Maverick13's Avatar
I did a search and no one talks about the GXL. Everyone talks about the GTUs, the 88 GTU, and the sport edition.
I konw that the GXL is the luxury model basically, but does it have 4piston calipers and a aluminum hood? Do only some have a aluminum hood?
Old Aug 28, 2002 | 10:23 AM
Felix Wankel's Avatar
Super Newbie
They all had 4 piston calipers.
I don't think you will find one with an aluminum hood.
Old Aug 28, 2002 | 10:29 AM
SirRX7's Avatar
Epitrochoid Knight/Mod
I recently picked up an 88 GXL parts car and it had an aluminum hood. I can't tell you if it was there from the factory of if someone added it later on though.
Old Aug 28, 2002 | 11:12 AM
banzaitoyota's Avatar
What Subscription?
My 2 88 GXL's had steel hoods
Old Aug 28, 2002 | 11:15 AM
blu_gxl's Avatar
my 87 gxl has an aluminum hood original stock
Old Aug 28, 2002 | 05:43 PM
rxspeed87's Avatar
what had alum and what had steel
or did the mazda guys just drink a lot of sake and put them on what they wanted to?
Old Aug 28, 2002 | 05:53 PM
SPDST3R's Avatar
I believe aluminum hoods are optional for GXL cars.
Old Aug 28, 2002 | 06:02 PM
rxspeed87's Avatar
and an option for TII also?
is it just an option or luck of the draw?
Old Aug 28, 2002 | 11:07 PM
jrx13's Avatar
I am not 100% sure but I think all automatic and convertibles came with aluminum hood. Just look for those.
Old Aug 29, 2002 | 12:02 AM
silverrotor's Avatar
If the Aluminum hood was an option on gxl's than my 88 gxl came with a steele one.
I've since swapped It out with a Turbo II one.
Old Aug 29, 2002 | 12:03 AM
Super Newbie
That seems to be the case right there.
Old Aug 29, 2002 | 12:50 AM
boosted12a's Avatar
I no nothing
i dont think that the alloy hood was standard on the autos. i just got some parts from a 91 gtu auto. that hood was steel. it also didnt have the 4 pot calapers but it was the 5 lug.......anybody got an answer for that one??????
Old Aug 29, 2002 | 12:54 AM
Super Newbie
Some S5 cars had the single piston calipers, but the 4 lugs were discontinued in 88. So therefore you get lots of 5 lug single pot cars.
Old Aug 29, 2002 | 12:57 AM
SonicRaT's Avatar
Super Raterhater
I think it was luck of the draw, my friends 88 vert has an alluminum hood. My 89 GXL has a steel hood, his other 87 NA has a steel hood, and our 86 has a steel hood too
Old Aug 29, 2002 | 08:02 AM
benhart21's Avatar
0-60 in 15 minutes
Mine's got 4 piston calipers, an aluminum hood, and 5 lugs
Old Aug 29, 2002 | 08:14 AM
Zaxfire's Avatar
Mine looks just like Benharts so I guess I have all the same as well..I do know I have 5 lugs..The aluminum hood I am not sure off..How do I tell if it is aluminum??
Old Aug 29, 2002 | 08:34 AM
benhart21's Avatar
0-60 in 15 minutes
All Sports came with alum. hoods
Old Aug 29, 2002 | 10:02 AM
DroptopRX7's Avatar
Some of the early turbo's came with steel hoods, some of the GXL's, S4 versions, came with aluminum hoods. Convertibles had aluminum hoods as do the later S4 and S5 Turbo's.
Hit or miss on the early sports and the GXL's. I think you'd be hard pressed to find an S5 GXL with an aluminum hood unless retrofitted.
Broad statements indicating this or that had this or that option are generally inapplicable to these cars, especially in the early years.
The S5 GTU was the bottom of the line. It did not have the larger brakes period. Even the 91 coupe which did not have a separate designation, had the weaker brakes if you chose the lower accessory group as opposed to the one that made it more like the GXL of previous years.
Old Aug 29, 2002 | 10:09 AM
RylAssassin's Avatar
Ask Icemark He knows all the **** that came stock with 2nd gens
Old Aug 29, 2002 | 10:11 AM
Super Newbie
No they don't. My brother's old Sport had a steel hood.
Old Aug 29, 2002 | 10:57 AM
turboren's Avatar
My 91 A/T has a steel hood, but 4-piston calipers. From what I've read, all 91's came with 4-piston calipers.
My first 86 had 4-lug hubs and an aluminum hood, stock. Figure THAT one...
Ren
Old Aug 29, 2002 | 11:03 AM
KiyoKix's Avatar
13B N/A POWA!
My '86 GXL 2+2 has 5 lugs, 4 piston calipers, and a steel hood (damnit...2 out of 3 ain't bad).
Old Aug 29, 2002 | 11:30 AM
rxspeed87's Avatar
you suck
I have an 87 sport with all but the alum hood
uh the steel hood is stronger so you wanna trade
Old Aug 29, 2002 | 11:43 AM
DroptopRX7's Avatar
According to the 91 dealer brochure, there were two versions of the 91 coupe you could get. The lower or higher level for sake of argument.
If you chose the lower level, it ended up being like the previous years GTU, the higher level like the GXL.
I want to double check the brakes. I am curious to see if they changed depending on what level you chose.
Old Aug 29, 2002 | 11:48 AM
What Subscription?
My 86 sport has a steel hood, the 88 vert carcas had a AL hood, 86 GXL had steel, 88 GXL had steel, 89 GXL had steel. 86 base in JY has an AL hood{IT IS TOAST,however}
