How far can I advance the timing with (mods)
Old Aug 27, 2002 | 06:58 PM
von's Avatar
von
Basically Mazdaspeed7 mods. But I have a S-AFC and am leaning out a big. All the manifold Porting has been done. Thnx.
89GXL
Old Aug 27, 2002 | 08:48 PM
mazdaspeed7's Avatar
mad scientist
Because you have it leaned out some, youll need to run higher octane or run less advance than you could without the S-afc. I would advance it a few degrees, to maybe 23-25 total advance, and see how your car does. If you feel a loss of power in the low to mid range RPM's, and/or hear a faint crackling sound(kinda like popcorn popping) back the timing off a little, or put higher octane in.
Old Aug 27, 2002 | 08:51 PM
eViLRotor's Avatar
Brother of the Rotary
Man, adjusting ignition maps and leading/trailing split is an art that very few people know.
For my TII, as an example:
In the high load areas in the meat of my powerband I havet the timing around 20. In the higher rpm at low loads its up 34.
Anyways, what I'm trying to say is that with a TII, you can advance it pretty far...
Old Aug 27, 2002 | 09:46 PM
von's Avatar
von
At high rpms Im sure thiers lots of load when your flooring it
Old Aug 27, 2002 | 10:55 PM
CaR 13's Avatar
whats S-afc?
Old Aug 28, 2002 | 12:08 AM
mad scientist
Originally posted by CaR 13
whats S-afc?
Apex'i Super Air Fuel Controller. It modifies the AFM signal to increase or decrease the injector pulsewidth. The rx7 store sells it if you want to check it out more.
Evilrotor, calm yourself He's talking about advancing the base timing on the stock ECU by turning the CAS.
Old Aug 28, 2002 | 12:16 AM
Felix Wankel's Avatar
Super Newbie
AIR FLOW CONVERTER!!!!
Old Aug 28, 2002 | 12:40 AM
mad scientist
oops.....i was pretty close though...
Jan 11, 2016 04:08 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
Aug 21, 2015 08:35 PM
20B Forum
Aug 19, 2015 01:47 PM
