Sponsored by: CARiD
vaccume and plug help???
Old Aug 24, 2002 | 02:46 PM
Rx-7Blazin's Avatar
Question vaccume and plug help???
can someone help me find out where these plugs and vaccumes go
First passenger side by exhaust manifold
Old Aug 24, 2002 | 02:48 PM
Rx-7Blazin's Avatar
next a randome hose found lying ontop of the windsheal wiper motor
Old Aug 24, 2002 | 02:51 PM
Rx-7Blazin's Avatar
a big possiblility for my problems this was found on the drivers side on the intake manifold almost at the bottom of the manifold found with a peice of electrical tape on the end
Old Aug 24, 2002 | 02:52 PM
Rx-7Blazin's Avatar
this wire was found by the fire wall and the side of the car on the drivers side
Old Aug 24, 2002 | 02:54 PM
Rx-7Blazin's Avatar
these wires where found on the drivers side twards the front by the distributer
Old Aug 24, 2002 | 02:56 PM
Rx-7Blazin's Avatar
oops here is the pic ^^^^^^^
l l l l l l l
Old Aug 24, 2002 | 02:58 PM
Rx-7Blazin's Avatar
here is a wire by the alternator
Old Aug 24, 2002 | 02:59 PM
Rx-7Blazin's Avatar
here is the last one found behind the air box
Old Aug 24, 2002 | 03:02 PM
Rx-7Blazin's Avatar
i realize that alot of the wires probly arnt supposed to be hooked up but the vaccume lines should be and i need to figure out where they go If anyone knows where any of these go reply with the picture number and where they go(if you can take a pic it would be good) thanks
87 rx-7 GXL with the engine transplanted by someone who knew nothing about rotory engines i dont know much about rotory yet but im learning and i just got this car about 2 months ago and it hasnt run right yet
Old Aug 31, 2002 | 11:57 AM
HAILERS's Avatar
HAILERS
1. First picture: It goes to a pipe approx and inch behind the rear auxillary actuator.
2. Second picture: Windshield washer hose. Attaches to the hood.
3. Third picture: See your orange connnector? Look straight down on the aft edge of the orange connector and you see two metal pipes sticking straight up. It goes on the most fwd of those two.
4. Forth picture: Leave that alone . Its for a test rpm meter. Do not ground or the car is a gonner!
5. Fifth picture: Dittos to answer four. DOn't connect a thing to it or the car is dog meat.
6. Pretty sure it was for cars that have an electric fan for the a/c. You have no sensor, so tie it back.
7. The yellow plug is for pressurizing your fuel rails without starting the car. Its used to check for fuel leaks. You put a jumper b/t the two sockets, turn the key to on, and that makes the fuel pump come on and then you look for leaks..........the green plug is for checking the setting of the tps using a home made light assy. Make sure you make the assy out of leds from RAdio Shack. Do not use common light bulbs or the ECU will go tango uniform.......the brown wire is a mystery. If the other end is on a lug going to the chassis, I'd suspect the guy used that wire for the yellow fuel connector. Instead of jumpering the two sockets in the yellow connector, he inserted that wire in one of the sockets to complete the circuit. Won't hurt which you insert it into, but matter which if you want the pump to work. See, one of the two sockets in the yellow connector IS a ground wire. So if you put that brown wire in that socket nothing will happen. You would have to put it in the other socket to make the pump work. Make sense????
This general rotary tech support forum is more or less a backwater. Take your post if its second generation relaated to the Second Generation forum for quicker responses. But if you prefer slow responses, post here.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
betes
Sep 27, 2015 08:25 AM
ZacMan
Sep 19, 2015 09:20 PM
sinistersam
Sep 13, 2015 07:17 PM
t-von
Sep 10, 2015 01:56 PM
