Help
Old Aug 22, 2002 | 11:38 PM
fdslave_g's Avatar
A capital FD barbie
Help
My Greddy Td07 has just broken any suggestion for new turbo?
(I'm dirving FD3S with modified 13B-rew)
And other thing is that my engine is always overheated. I've already chage my intercooler, yet it doesn't help much. Pls. Pls. Pls. give me some suggestion asap. I don't wanna dive 7 with original twin turbo
Old Aug 23, 2002 | 09:58 AM
Snook's Avatar
Tony Stewart Killer.
is this real?
those are some broad descriptions of your car and broad questions you are asking.
What mods do you have to your motor?
What kind of use will the turbo be for?
I understand that if you have another turbo going back to the twins is not exciting but it isn't that bad.
Are you really from thailand?
Yes or No? hahaha
Snook
Old Aug 23, 2002 | 09:53 PM
fdslave_g's Avatar
A capital FD barbie
Yup
The car is for daily life using so I'm not modify inside the engine. I just use Knight Sport ECU, ARC intercooler, Blitz Muffler, and some other detail. You know, girl's car. I just modify it so that no one would beat me up on the way to University.
And yes I'm from Bangkok, Thailand.
and that's my car
Old Aug 23, 2002 | 09:59 PM
black99's Avatar
Lurking..................
For the overheating problem, have you tried an aluminum radiator? If so maybe you should try replacing the thermostat. As for turbo reccomendations, there are many you could go with. But since your mods are light maybe the Apexi rx6?
Old Sep 2, 2002 | 11:18 PM
fdslave_g's Avatar
A capital FD barbie
gosh! where are other posts uhhhh!
Old Sep 2, 2002 | 11:20 PM
Mahjik's Avatar
Mr. Links
Arrow
Just keep the one thread, we don't need two for the same problem:
https://www.rx7club.com/forum/showth...hreadid=110687
Old Sep 2, 2002 | 11:21 PM
fdslave_g's Avatar
A capital FD barbie
Is it true that single TD-07 will get heated harder than original turbo?
Well, still when I had my single turbo on the car was overheated too.
The gauage is the stock temp guage and it climbing up to H when I go over 220Km/hr. I have to dlow down to 180-190 to keep it down.
Old Sep 3, 2002 | 12:27 AM
ROTARYFDTT's Avatar
Ding King
do you have an aftermarket radiator. If not GET ONE and see what happens because running those mods on a stock rad. could create such temps.
check out this link: http://66.216.67.51/subcatmfgprod.asp?0=352&1=354&2=-1
Old Sep 3, 2002 | 07:30 AM
Mahjik's Avatar
Mr. Links
That's not true... I'm running just about the same mods on the stock radiator and have zero cooling problems. Many others have ran much more than I have on the stock radiator.
The problem with the stock radiator is not necessarily it's cooling compacity, but it's plastic pieces that can crack from the heat.
Old Feb 28, 2003 | 08:22 AM
fdslave_g's Avatar
A capital FD barbie
now that's gonna be my new sig
