gas mileage on upgraded ECU
Old Aug 22, 2002 | 01:53 PM
Mahjik's Avatar
Mr. Links
Re: gas mileage on upgraded ECU
Originally posted by tamerlane
How does an upgraded ECU (Pettit, M2 or Apexi PFC) affect gas mileage? I currently have stock ECU with pettit intake, bonez dp and catback. I get really good gas milege (normal driving) and want to find out if an upgraded ECU would change that. I am looking at getting the Apexi PFC.
Thanks
Well, it seems each FD is different, but I've noticed no change in mileage since changing to the Pettit ECU.
Old Aug 22, 2002 | 02:18 PM
2 hott's Avatar
not sure what I was getting with the stock ECU since I switched it out 2 months after I got my 7. W/ the M2 I got an average of 23-24 mpg when I drove from FL to WI. City mileage seems to be a little lower my guess is because of the changed fuel maps.
Old Aug 22, 2002 | 02:41 PM
7-sins's Avatar
thats not paint....
Power FC uses the fuel pretty efficiently I think that would be a wise choice... I didn't really notice too much difference.
Old Aug 22, 2002 | 03:12 PM
rx-7ml's Avatar
Rotarian
It depends on the car, as each stock ECU has the same map, and works better on some engines than others due to small differences in construction. As a result, sometimes you'll get higher, sometimes lower sometimes the same mileage out your car.
The stock ECU as I understand it overfuels to keep it on the safer/reliable side, so by using a programmable ECU you can better tuned it for your individual motor, and get the best possbile MPG.
Old Aug 22, 2002 | 03:26 PM
zooq's Avatar
i get 12-14 mpg in town and 20-22 on the highway.
Old Aug 22, 2002 | 03:38 PM
rx-7ml's Avatar
Rotarian
zooq, is that on the standard ECU? oh, and is you foot made of lead
Old Aug 22, 2002 | 04:24 PM
Mahjik's Avatar
Mr. Links
With not much highway driving, I average around 13-14mpg no matter how hard or soft I drive the car.
If I add in more highway miles, then the average goes up, but normal city driving is aroun 13mpg no matter how I treat the car.
Old Aug 22, 2002 | 04:45 PM
the_glass_man's Avatar
Will u do me a kindness?
I get better mileage with my PFC then I did with my M2. The M2 was just programed to run rich.
Old Aug 22, 2002 | 10:36 PM
Nathan Kwok's Avatar
During cruising all the aftermarket "chipped" ECUs should be the same. They only start adding fuel in closed loop mode, so at 0psi/3k rpms. Then, things go quickly downhill . Programmable ECUs can be tuned to get even better mileage than stock, which is pretty cool. Lots of people have reported 1-2mpg better with PFC base maps, not a surprise since even the stock ECU is tuned richer than need be.
Tylerx7fb
39
May 27, 2019 12:45 PM
12abridgeport
Aug 17, 2015 06:28 PM
