why do ported engines have less compression?
Old Aug 19, 2002 | 12:20 PM
poor college student's Avatar
Red Mist
see title...
Old Aug 19, 2002 | 12:33 PM
DaleClark's Avatar
RX-7 Bad Ass
There is more overlap between the intake and exhaust, so at low speeds some of the intake charge can "leak out" the exhaust port. The less air you have to compress, the less compression you'll have.
Once the motor gets up to speed it's less of an issue - the rotor is turning fast enough that there isn't enough time for the overlap to cause intake dilution. You can also, in some instances, get a scavenging effect where the exiting exhaust gasses help suck in more intake air, giving a fuller charge at higher RPM.
Dale
Old Aug 19, 2002 | 12:42 PM
Red Mist
ooOOoohh.... i get it.... thanks dale
~Jeremy
elfking
Aug 19, 2015 09:48 PM
Wolf_
Aug 11, 2015 04:23 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
