Help with Fuel for an XST04S
Old Aug 18, 2002 | 08:23 AM
manatecu's Avatar
I am getting ready to install a new XST04S into my rebuilt streetported motor. I have a Nip high flow pump and SX regulator. I have been reading past posts about injectors and can not decide what to use. I will be using at PFC to control. Can I use 1300's or do I need 1600's with a resistor? What size resistor do I need and which side do I put it on? What fuel pressure do I need to run. Thanks in advance for any help.
Note: I want to tune for 1 bar.
Thanks
Chris
Old Aug 18, 2002 | 09:40 AM
Wargasm's Avatar
Weird Cat Man
Chris,
I tried using some overbored injectors at 1300, and was getting about 85% duty cycles at only 11.5-12 PSI. I didn't want to push things, so I went with the 1600s + resistors.
I am running about 40 PSI of pressure at 0 manifold pressure. This is about what the stock system runs. So at idle you have vacuum, so it drops the pressure down to about 31-32 or so.
Resistors go on the "+" side of the injector. I believe that on our cars, it's black with yellow stripe or something like that. I used one 10 Ohm, 20 Watt resistor on each new secondary injector. Since 10 Ohm, 20 Watt is hard to find, they are actually four 10 O, 10 W connected together in a diamond shape to make what I wanted. Lots of other people say that 10 O, 10 W just by itself is fine and use that.
Brian
Old Aug 18, 2002 | 11:02 AM
manatecu's Avatar
Are you saying that you used 4 - 10O, 10w per side or 2 - 10ohm, 10w per injector. Just curious was that something Dave recommended?
Thanks
chris
Old Aug 18, 2002 | 11:21 AM
Wargasm's Avatar
Weird Cat Man
I used 4 x 10 Ohm, 10 Watt per injector.
Each set of 4 is wired into a diamond shape so you end up with this:
____^v^v^____^v^v^____
INJECTOR-----< >------Wiring Harness
\___^v^v^____^v^v^____/
This gives an overall effect of 10 Ohm, 20 Watt.
I believe that Dave actually uses 3 Ohm, ?? Watt. I don't know for certain, so don't take it too seriously.
The way I arrived at my setup was I just calculated the difference in resistance from stock 850s to low impedance 1600s. It is about 10 Ohm. Then for the wattage, I just used V = IR and P=IV to find the value I wanted. I think that with 20 Watts I'm pretty damn safe.
I think that most people just use 10 watts.. so maybe that's OK too.
Old Aug 18, 2002 | 11:24 AM
Wargasm's Avatar
Weird Cat Man
Damn that picture looks like ***. I am no ASCII artist!
Brian
Old Aug 18, 2002 | 11:32 AM
Wargasm's Avatar
Weird Cat Man
I am quite the artist!
Here's how I did em....
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
